Old 06-12-2011, 11:16 PM
Julia B Julia B is offline
Default Multiple interfaces
I've got a Fast Track Pro. I've got some VIs that don't like the M-Audio ASIO driver. Yes, I use a couple different DAWs. I tried ASIO4ALL, and the programs like it but the Fast Track Pro doesn't seem to like it. I need an ASIO driver so that I don't have a ton of latency with the VIs.
I'm thinking of picking up a Focusrite Saffire 6 and using that for the other DAW, and keeping the FTP for Pro Tools.
Would Pro Tools freak out if it saw two USB interfaces? Or would I have remove the Focusrite interface when I use Pro Tools? The other DAW will use either.
It's the VIs that are an issue.
Model : Intel(R) Core(TM)2 Quad Q6600 2.40GHz
IDC : 4x 32kB, Synch, Write-Thru, 8-way, 64 byte
L2 : 2x 4MB, ECC, Synch, ATC, 16-way, 64 byte line sz, 2 thds sh
Mainboard: DFI Inc. INF P35-R
BIOS : Phx Tech, LTD 6.00 PG 03/11/2008
Bus(es) : ISA X-Bus PCI PCIe IMB USB i2c/SMBus
MP APIC : Y
Tot Mem : 3.25GB DIMM DDR2 (WinXP)
Chipset: Intel P35/G33/G31 Proc
Front Side Bus Spd : 4x 266MHz
Mem Bus Spd : 2x 399MHz
(C:) : (250GB, SATA, 8MB Cache)
(D:) : (250GB, SATA, 8MB Cache)
Old 06-13-2011, 04:26 AM
sunburst79 sunburst79 is offline
Default Re: Multiple interfaces
It shouldn't be an issue. Pick to one you want to use and PT should default to it.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 06-13-2011, 08:39 AM
Agreed, but if you plan on using the Fast Track as the audio engine, I would uninstall ASIO4ALL and go with M-Audio drivers(ASIO4ALL was terrible on my laptop with the Fast Track Pro, but M-Audio drivers work fine. Pro Tools will(SHOULD) recognize any and all midi ports(as long as drivers are installed). I ran midi via my DIGI003, M-Audio Uno and MOTU FastLane USB all at the same time(Windows XP). Since going to Win7, the UNO would not cooperate(so its gone now)
Old 06-22-2011, 08:07 PM
bonestonne bonestonne is offline
As far as I'm aware, Pro Tools M-Powered only works with M-Audio devices. You'd need to be using the regular Pro Tools 9 in order to use any interface you wanted.
Dual Xeon E5-2620|Asus Z9PA-D8|WD 250gb Raptor SATA-III|32GB Kingston DDR3|WD Blue 640GB SATA-II (x2)|nVidia GTX660 Ti 2GB|Antec HCG-750|NZXT Source 210 Elite
Windows 8.1 Pro x64 with Media Center Pack
15" MacBook Pro 8,2|2.2GHz i7|16GB RAM|750GB drive
Mac OS 10.8.5 x64
Pro Tools 11 with M-Audio ProFire 2626 on both machines
Multiple interfaces in pt9 HD? muddboy macOS 7 05-12-2013 11:23 AM
Multiple interfaces to PT9 towelhead macOS 3 05-26-2011 10:18 AM
multiple interfaces with pt9 rivetheadsound Pro Tools 9 22 04-21-2011 10:33 AM
Multiple Interfaces? grimepoch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-01-2008 06:30 AM
AES/EBU on multiple 96 interfaces Robin Reumers Pro Tools TDM Systems (Mac) 0 10-12-2006 09:41 AM
