protools 8.0.4 audio driver freeze
i recently built a i7 gigabyte udr3 motherboard i7 930 1366 socket 8 gb memory i have 4 hardrives 1 with windows 7 64 another with windows 7 32 and the other 2 is for back up.anway protools work fine the problem am having is i cant use my digi 003 rack audio driver in fl studio it freezes i know its not my 003 rack because i have no problem when recording or playing back audio in protools.when i was using windows xp and protools 8.0 i had no problem with the old driver working in flstudio. i did every thing uninstaling and reinstaling abd nothing work am fed up i have to use asio4all and use my computer speakers to playback myb track in flstudio and its not the sam i miss playing my flstudio track with my 003 rack in my studio monitors,if anyone have any solutions please share them with me because i give up
Re: protools 8.0.4 audio driver freeze
pls check your audio prereference on fl - 804 sometime chance format on asio driver - if we used from pt to another daw - also check on audio prereference on your computer - my system working ok but sometime freeze on 003 but operating ok - ignored - and if load pt804 again system ok -fl reaper - ableton - reason - acid and cubase working - and dts promised 804 cs1 to solved 003 freeze soon
i check the preference of flstudio it has like 8 other 003rack audio driver options 1.asio direcx full duplex when i choose it the buffer size is set at 2040 samplerate 43ms deley and it wont let me change it.2.asio multimedia 2040 buffersize no changing option either 96ms delay and the others are digi 003 rack analog 1/2 digi 003 rack.digi 003 s/pdif 9/10 digidesign 003 i tried every thing as i said when i had windows xp and protools 8.0 i have no problem using my 003 rack driver.the asio digidesign driver fw003 is the one that has adjusttable buffersize i guest thats the one that replaces the protools 8.0 original audio drive.but if i can get that drive to work or if there any tirdparty driver that i can use with my 003 rack that would be great
8.0.4 has ASIO problems for a number of people. As I understand it, it is a known problem and will be addressed with the next update. It may be next week, or it may be next year, no one knows when they will release it.
Protools could not initialize audio driver | def3mno62 | Third Party Interfaces | 7 | 04-03-2014 04:15 PM |
protools 8 audio driver not recognize | eranf | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-13-2010 12:52 AM |
Mbox2 Driver Issues/Freeze/Hardware... XP | blairl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-23-2010 01:55 PM |
Core Audio Driver (v1.2)makes G4 Freeze..... | Michael Harnois | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-27-2003 12:46 AM |
digi output driver freeze-up | joshua d | Pro Tools TDM Systems (Mac) | 0 | 06-25-2000 02:24 PM |
