Old 07-17-2009, 07:59 PM
yanncrusoe yanncrusoe is offline
Default separate HD for BFD2 from audio files???
Im having some probs with PT crashing alot and the report always refers to BFD2 being the culprit. I moved BFD2 from my system drive to my Audio HD where all my recordings go, but now the same crashes occur even though BFD2 isnt on my system drive anymore. Do you think i should have a seperate drive for BFD2?? BFD2 is about 55GB.
thanx in advance
MBP 17" 2.4 ghz, 320gb 7200 , 4 GB RAM, Glyph GT050Q, 10.5.7
Mbox2, PT8cs3, BFD2
www.myspace.com/yanncrusoe
Old 07-17-2009, 08:17 PM
Default Re: separate HD for BFD2 from audio files???
Make sure you're running BFD 2.1.0.47
It's recommended that you have the BFD samples on a dedicated separate physical non-system drive.
Crashes are normally due to exceeding the RAM available in Pro Tools... are you running any other VI's at the same time?
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 07-17-2009, 09:29 PM
The only other VI's Im running are Xpand. im using reverbs and delays too, just the stuff that comes with 8. Ive got all the BFD samples on my Audio HD where my work gets recorded to.How do i know how much RAM is available in Pro Tools?
HW buffer size set to 256/512
Mbox2, PT8cs3, BFD2
Old 07-17-2009, 10:35 PM
Check your version number - and post on the FXpansion forum with screen shots of your BFD2 Engine settings.
Cheers,
Rail
Platinum Samples
Old 07-18-2009, 02:53 AM
TOM@METRO's Avatar
Use the ‘Load-on-demand RAM’ optimization in BFD2.1.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 07-18-2009, 05:36 AM
thanx, i am, as well as 16bit rate and im using the latest version.
still have crashes though
Mbox2, PT8cs3, BFD2
Record an audio trk from BFD2 - i/o routing? Reesho 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-05-2008 11:07 AM
exporting separate audio files simultaneously brenmcg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-17-2008 02:18 PM
regions into separate audio files..? DJ FADE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-26-2007 04:53 PM
How do I separate audio and PT files across different drives? JMS40 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-07-2002 12:20 AM
Duplicate files on separate drives??? Gulliver 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-07-2001 11:22 AM
