Formatting External Harddrive Mac OSX
Hi, I was wondering how to format an external firewire harddrive for record/ playback only to make it useable with pro tools? Im new to Mac OS and Pro Tools as well... plzzzzz help!! thanks!!
Macbook 2.0 GHZ Pro Tools Le 8 MBOX 2 Pro OWC 160 GB external Drive ( needs to be formatted Please help )
Macbook - 2.0 GHz Intel Core 2 Duo, 4GB DDR2 Memory, 120GB Serial ATA Drive Mbox 2 Pro (Firewire) - Pro Tools LE 8 OWC External Drive Record / Playback |
Re: Formatting External Harddrive Mac OSX
The Mac has a "Disk Utility" application for assorted tasks you need to learn to do as a Mac user. You can format a drive using Disk Utility and want to format it for Mac OS Extended and Journaled. Disk Utility has good online Help to get you going.
Steve B. ---------------------------------------------------------------- If you think you can or if you think you can't, you're right. |
docbop- thanks for the quick reply! do you think that you could post any links that may be helpful or give me a step by step instructions to format this drive? the drive is 160 GB do I need to partition it? any more thoughts on this would be sooo helpful
I'll chime in. Hit shift+command+u that should open up the utilities folder. Then open up disk utility. It should show the drive on the left of the screen (assuming you have it mounted i.e. plugged in). I believe under the erase tab is where you'll be able to format it. I personally wouldn't partition it. More partions makes the drive work harder as it has to try and read/write each partition seperately. And the data it needs could be far apart. FWIW I keep disk utility on the dock as you should choose your OS disk (the one on top that says how big it is and what brand) and repair permissions after you install any software.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier. |
CME cheers man thanks... so Ive opened up disk utility.. now should I plug in the external drive? please man step by step instructions to format this thing. I just got my macbook about a week ago and Im itching to start recording ..
check out this step by step video http://www.youtube.com/watch?v=LN5my4Lrd-4
basslik thanks!! perfect :)
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
A good friend of mine said to make sure & format an external drive for use with Pro Tools as Mac OSX Extended & NOT Journaled. Can any of you confirm this? Thanks. -john
I have always formatted "Journaled." Never heard anything to suggest it shouldn't be.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
external Harddrive | Talisker | Pro Tools 9 | 7 | 07-12-2011 08:03 PM |
external harddrive | studiokeyz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-27-2007 02:56 PM |
External Harddrive | Drew Witt | Pro Tools M-Powered (Mac) | 1 | 08-11-2005 05:54 PM |
External Harddrive Help | Brubacher | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-18-2005 05:40 PM |
external harddrive | Tuur | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-18-2004 05:40 PM |
