Old 10-30-2007, 01:41 PM
HesamIAm HesamIAm is offline
Default Digi 003
Hello,
I just bought a Digi 003 console. I am just wondering if it is normal for the display to show "Pan L" by default when you turn on the 003.
Would anyone know why it does that and if Pan L means that the master out is set to Left Pan?
Thanks in advance,
Hesam
Old 10-30-2007, 02:39 PM
robob robob is offline
Default Re: Digi 003
Hello,
Thanks in advance,
Hesam
Yes, Pan L in Pan View is the default startup for a 003 in ProTools.
Read the manual and you will know what it means.
Good Luck,
Robert A. Ober
Old 10-31-2007, 12:43 PM
Thank you.
Old 10-31-2007, 03:41 PM
GORILLA GORILLA is offline
Good Luck,
Robert A. Ober
Wow thats weird. Mine says 003 offline.
METAL LABS
Old 11-03-2007, 08:43 AM
Good Luck,
Robert A. Ober
Maybe your are trying to be a smartalex, but if it is offline in ProTools (which I did state) then you have a problem.
Old 11-03-2007, 08:54 AM
Forum Member LE Forum Member LE is offline
Good Luck,
Robert A. Ober
He's not being a smart*ss you said when you turn on the 003 you never said when PT is open.
Since the 003 is supposed to be turned on prior to opening PT why would someone think you meant when PT is open?
Yes the Pan L is normal as the manual states, it was is currently being viewed and controlled.
Makes sense because of how the panning works on PT tracks.
Your original post
Hello,
Thanks in advance,
Hesam
Old 11-04-2007, 12:09 PM
[/QUOTE]
[/QUOTE]
[/QUOTE]
Your original post
Hello,
Thanks in advance,
Hesam
[/QUOTE]
Nope, your confusing me (robob) with the original poster. I did reply to the OP (original poster) as such:
I did make the leap that the OP was referring to startup in PT. Offline is the correct for power on prior to launching PT or something that loads the Core Audio driver.
Maybe we should chill.
Y'all be cool,
Robert
Old 05-09-2013, 08:14 PM
wearetheniceguys.com wearetheniceguys.com is offline
how do you pan a stereo track all the way to either side?
Digi 002 not recognized by MacBook Pro - Digi CoreAudio not working GuidoC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-04-2011 09:37 AM
Digi hardware - bizarre behavior - Digi you will lose this market share andre67 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 27 02-26-2010 07:45 PM
Digi TS: Problem w/current Digi Core Audio Manager Armando Pro Tools TDM Systems (Mac) 4 10-11-2006 10:08 AM
Digi - Reinstalled OS, PT LE, can't reauthorize Digi 002 pack plugins OneMadSon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-04-2003 04:20 PM
Wha is the name of the digi cable to hook up Apogee digi 8+ card called??? leon777 Pro Tools TDM Systems (Mac) 4 04-15-2002 02:44 PM
