Worth it to add DSP Farm Card??
Hello all ...
Our system is Mix core and one DSP Farm PT 6.4.1 and Mac G4 933. The engineer needs to use more TDM plug ins. If we add another DSP farm ( currently on the the shelf needing upgrade ) how many more TDM plug ins will this allow us to run? If we do go ahead and add this card we'll have to use a MAGMA PCI expansion chassis forcing us to move our MIX, MiroMotion and ATTO cards around to make room ( aarrg what a nightmare ) . Please advise. Thanks Joel
MacPro 5,1 - 2 x 2.66 6 core - 32G Ram - SSD's - Mac OSX 10.12.6 - HD Native Card - Omni - Focusrite RedNet 5 - Avid Dock - iPad2 |
Re: Worth it to add DSP Farm Card??
One (OLD) DSP Farm should give you approx 4 more plugin's depending on the plug. A Mix Farm approx 6 more.
As for the expansion chassis, I kept both my SCSI and Miro card in the Mac and just put the PT cards in the expansion. I found this worked best especially for the Miro card. Hope this helps Rod
http://www.imdb.com/name/nm0639795/ |
If you need an expansion chassis, drop me an email. I've got two 13 slot Magma chassis that were used with MIX systems on G4s. You should be able to find a DSP Farm used for $200-50. I believe the upgrade cost is $120, just to keep it in perspective.
Amp farm 3, worth upgrading? from 2.4!! | crizdee | Pro Tools TDM Systems (Mac) | 5 | 11-18-2005 06:20 PM |
DSP Farm Versus Mix Farm Card | dharpo32 | Pro Tools TDM Systems (Mac) | 1 | 12-17-2003 08:49 PM |
processing power QE farm card vs. mix farm card | lennox | Digidesign Hardware & Software | 3 | 03-03-2003 02:24 PM |
'Classic' Farm vs. Mix Farm card - both have SRAM? | Last Legend | Pro Tools TDM Systems (Mac) | 1 | 02-15-2003 04:46 PM |
WTB: MIX FARM or Trade D24 Farm CARD | JLEpperson | Pro Tools TDM Systems (Mac) | 2 | 06-02-2000 11:15 AM |
