Old 07-16-2019, 06:38 AM
richardbutler richardbutler is offline
Default Re: 2019.6 And The Disappearing Plugin Window?
Originally Posted by BScout View Post
Not a bug.
Mentioned specifically in the release notes of Eucontrol 2019.5 as a new feature. Didn't exist before (which is why there is a "legacy" option on the left column to switch it to how it was before for attentioning)
(yes, this is a global item and not plugin-brand specific)
Thanks for the clarification, much appreciated
Old 07-17-2019, 06:28 AM
PhilSchroeder's Avatar
PhilSchroeder PhilSchroeder is offline
It is INEXCUSABLE that Avid would put a PT behavior preference in the Eucon software. And on top of that, "Tech Support" doesn't even know about this. I reported this problem right away after 2019.5 came out (new Eucon dropped at the same time) and they were clueless.
Old 07-17-2019, 11:31 AM
BScout BScout is offline
If you don’t use Eucon, then it wouldn’t happen/apply. That’s why it is there in Eucontrol. Also Eucon is used by more than ProTools and these aspects can influence other programs that use Eucon.
As for Avid CS not knowing, that is an issue.
2019.5 MIDI events randomly disappearing when copying regions XJENSEN Pro Tools 2019 5 05-11-2019 05:09 PM
Disappearing tracks in edit window waswillbe Pro Tools TDM Systems (Mac) 3 02-01-2011 10:05 AM
Disappearing Tracks in Edit Window only dergutetonffm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 01-16-2011 06:45 AM
Is It Possible To Keep The Midi Event Window From Disappearing? epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 12-30-2009 03:38 AM
Disappearing edit and mix window 6.1 mostlypost Pro Tools TDM Systems (Mac) 0 09-30-2003 11:14 PM
