Old 03-11-2011, 05:18 PM
remis remis is offline
Default 9.0.2 and updated 003 drivers, but no mbox 2 pro driver update?
Just wondering maybe if DTS might be able to chime in here. I filed a case ages ago with tech support regarding what appear to be driver issues with the mbox 2 pro with any version of pro tools under windows 7 64bit since the first release (8.0.4). The issues are these; often, when opening a session the mbox does not seem to spring into life, the lights are on but nobody is home. The session will playback but no sound comes from the interface. I found the only way to get it to work was to open a certain session that always seemed to work off the bat. It still happens on occasion, but is a bit random. The other issue is when using the mbox as the main sound card for the computer. Sound comes out fin using itunes, windows media player etc, but if you pause the audio or video then it won't resume afterwards. I've confirmed this with other mbox 2 pro users on the forum also. But just to be clear, this Is only when using the interface outside of pro tools.
I was told by avid support that this was reproduced and would be in a future fix...but that was mid last year from memory. Any word on this? I'll post my Sandra bellow as well, for completeness
SiSoftware Sandra
Computer
Model : Gigabyte X58A-UD3R
Workgroup : WORKGROUP
Host Name : Remis-PC
User : Remis
Processor
Model : Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz
Speed : 3.8GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 2 Unit(s)
Type : Quad-Core
Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing
L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing
L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 8 threads sharing
Computer
Mainboard : Gigabyte X58A-UD3R
BIOS : Award (Phoenix) FB 08/24/2010
Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 12GB DIMM DDR3
Chipset
Model : Giga-Byte X58 I/O Hub
Front Side Bus Speed : 2x 3GHz (6GHz)
Chipset
Model : Giga-Byte Core Desktop (Bloomfield) UnCore
Channels : 3
Memory Bus Speed : 2x 825MHz (1.65GHz)
Memory Module(s)
Memory Module : Corsair CMD12GX3M6A1600C8 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5)
Video System
Video Adapter : ATI Radeon HD 5700 Series (800 SM5.0 860MHz, 1GB DDR5 4x1.2GHz, PCIe 2.00 x16)
Graphics Processor
STREAM Processor : ATI Radeon HD 5700 Series (800SP 10C 860MHz, 1GB 4x1.2GHz)
Compute Shader Processor : ATI Radeon HD 5700 Series (800SP 860MHz, 1012MB 4x1.2GHz)
Storage Devices
WDC WD10EADS-00L5B1 (1TB, SATA, 3.5") : 932GB (E:)
WDC WD1002FAEX-00Y9A0 (1TB, SATA300, 3.5", 7200rpm, NCQ) : 932GB
WDC WD5001AALS-00LWTA0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 466GB (C:) (D:)
WDC WD10EADS-00L5B1 (1TB, SATA300, 3.5", NCQ, 32MB Cache) : 932GB (H:)
HL-DT-ST DVDRAM GH22NS50 (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (I:)
Logical Storage Devices
Documents (E:) : 932GB (NTFS) @ WDC WD10EADS-00L5B1 (1TB, SATA, 3.5")
System Reserved : 100MB (NTFS)
Backups (H:) : 932GB (NTFS) @ WDC WD10EADS-00L5B1 (1TB, SATA300, 3.5", NCQ, 32MB Cache)
Hard Disk (C:) : 195GB (NTFS) @ WDC WD5001AALS-00LWTA0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache)
Storage (D:) : 270GB (NTFS) @ WDC WD5001AALS-00LWTA0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache)
Optical Drive (I:) : N/A @ HL-DT-ST DVDRAM GH22NS50 (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : Giga-Byte LPC Interface Controller
LPC Legacy Controller 1 : ITE IT8720F
Audio Device : Giga-Byte HD Audio Controller
Audio Device : PC Partner EG JUNIPER XT Audio Device [Radeon HD 5700 Series]
Audio Codec : ATI (AMD) HDMI Audio
Disk Controller : Giga-Byte 6 port SATA AHCI Controller
Disk Controller : Giga-Byte 88SE9128 SATA-600 Controller
Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller
USB Controller 1 : Giga-Byte USB UHCI Controller #4
USB Controller 2 : Giga-Byte USB UHCI Controller #5
USB Controller 3 : Giga-Byte USB UHCI Controller #6
USB Controller 4 : Giga-Byte USB EHCI Controller #2
USB Controller 5 : Giga-Byte USB UHCI Controller #1
USB Controller 6 : Giga-Byte USB UHCI Controller #2
USB Controller 7 : Giga-Byte USB UHCI Controller #3
USB Controller 8 : Giga-Byte USB EHCI Controller #1
FireWire/1394 Controller 1 : Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller
SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Network Services
Network Adapter : Realtek PCIe GBE Family Controller
Wireless Adapter 1 : Broadcom 802.11n Network Adapter
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7600
Platform Compliance : x64
Windows Experience Index
Current System : 5.9
PT10, Focusrite Liquid Saffire 56, Eleven Rack, i7 950 @3.80GHz, Noctua NH-D14 CPU cooler, GA-X58A-UD3R, Corsair CMD12GX3M6A1600C8 12GB, SAPPHIRE VAPOR-X HD5770 1GB GDDR5 PCIE, Caviar Black 500GB 32MB Cache OS drive, 2x Caviar Black 1TB 64MB Cache Sata3 (Audio and library), Broadcom BCM94322MC wireless network adapter
W7 - 312 dverbs @ 64 buffer/ 403 dverbs @ 1024
Old 03-14-2011, 06:55 PM
Default Re: 9.0.2 and updated 003 drivers, but no mbox 2 pro driver update?
Anyone from avid able to comment?
Old 03-16-2011, 10:56 PM
Dts???
Old 03-17-2011, 01:34 PM
mblanton66 mblanton66 is offline
I have an 003R+ as well as an MBox 2 Pro. As I understand, you are correct. They only recently updated the drivers for the 003 family. I don't think the issues they were looking to fix applied to th MBox 2.
That said, I have not tried my MBox 2 Pro with PT 9.02 yet.
Old 03-19-2011, 02:10 AM
Thanks for your input. I've tried 9.0.2 out with my mbox 2 pro today and still the issue persists, as I assumed it would.
Sure would be great if someone from Avid would be able to drop by...
Old 03-23-2011, 08:46 AM
Bump
Old 03-23-2011, 12:29 PM
Some shots in the dark since nobody's responding:
Does disabling any and all other audio devices on your pc (maybe through BIOS?) change this behavior?
Have you tried the legacy Windows firewire driver?
Is energy savings disabled on the firewire adapter?
That you can fix it by opening a certain session is a head scratcher.
I'll be using my MB2Pro this week with sessions I just recorded via my 003 and I'll see how it behaves. I'll try the WMP thing too. I'm running W7x64SP1.
Old 03-23-2011, 08:42 PM
Wierd. I was able to reproduce the WMP playback issue if I paused then minimized it. I'll try that with the 003 next time it's connected.
I spent 30 minutes or so in Protools and the MB2Pro worked fine.
I don't know ...
Old 03-24-2011, 07:00 AM
Unfortunately I'm away on site working this week, so am unable to try out your suggestions at present. I have disabled all other audio devices on my pc in the device manager, not sure if it would make a whole lot of difference doing it from the BIOS? But if you reckon it's worth a shot I may give it a whirl when I get home next week.
I don't remember using the legacy firewire driver...but will my MB2Pro actually still work using this?
I have gone through and optimized my pc according to Avids optimizations for W7, don't remember there being anything in there about disabling power saving on firewire...I didn't even know there was that option?
I don't know ...
Thanks for testing that out for me. Yeah, I heard from an Avid service dude that they were able to reproduce the WMP playback issue and would be in a future fix...but I'm just wondering if there's been any progress on that or not...
Yeah, the issue with it only giving me sound when opening a specific session seems odd. When I open that session I hear a pop through my headphones and the lights flash on the MB2Pro...almost like it engages at that point, even though it's already on and can play system sounds prior to opening PT. Wierd...
Mbox 2 USB Driver update theM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-29-2013 02:49 PM
Updated Mac Drivers for Mbox, Mbox Pro and Fast Track Ultra now available Avid Technical Alerts 0 10-30-2012 04:24 PM
Mbox drivers are messing with my PC. How do I remove or update them? uz3r 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-07-2010 08:43 AM
7.4CS10 Update requires updated Interlok Drivers? kfoody Pro Tools M-Powered (Win) 4 08-18-2009 09:11 AM
