Old 04-08-2020, 09:22 AM
bashville bashville is offline
Default Who still uses OWC Mercury Helios Thunderbolt2 for HD Native Card?
Hi reposting to "Hardware"--
I'm curious who still has this working with a laptop system. I've been successfully running a 2010 cheese grater with the card mounted inside connected to a blue 192. I got the OWC 5-6 years ago to run briefly with a laptop and it worked. Now I recently got a 2018 MacBook Pro, and tried to run the OWC solution with a TB3 to TB2 adapter, but no go. I'm curious if I should keep trying, or it anybody knows it simply won't work. As of two days ago (in High Sierra) my older desktop was running the Native card with the 192 just fine, so I'm thinking it's probably not the Digi unit's fault. The new system is running Mojave, and the PT is 2019.12. Thoughts? Thanks for any responses
Kevin
HD Studio, PT2022.6, UA Apollo x6, 2018 MacBook Pro, 32 Gig, Big Sur
Old 04-08-2020, 11:03 AM
reichman's Avatar
reichman reichman is offline
Default Re: Who still uses OWC Mercury Helios Thunderbolt2 for HD Native Card?
Are you missing a driver?
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 04-08-2020, 11:32 AM
The OWC works without a driver--I can see it in the system information. But the HD card itself does not appear. The driver for the card is appropriate to the version of PT I want to run (2019.12)
Old 04-08-2020, 11:54 PM
LDS LDS is offline
If you haven't already, try doing a PRAM reset a few times over and see if it helps. It has fixed similar issues that I have had in the past.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Old 04-09-2020, 04:28 PM
Aha I'll try that. I've also had issues where my external drives are somehow being set to read-only upon startup. So that sounds promising as well(?) for that maybe. thanks
Old 04-09-2020, 05:10 PM
Hugh-H Hugh-H is offline
Hello,
FYI the HDN card in an OWC Helios enclosure works fine with a TB2 laptop running OS10.14. You mentioned TB3 - in theory with a TB3>2 adaptor, sure, haven't tried it.
Hugh
Old 04-09-2020, 06:09 PM
Originally Posted by Hugh-H View Post
Hello,
Hugh
Thanks Hugh--are you running one of the last versions of P!12?
Old 04-10-2020, 12:14 PM
also wondering if I've been using this card "unflashed" the whole time. It worked in my mid-2010 cheese grater. I'll try to put it back in that machine and run Digitest on it.
Old 04-11-2020, 06:21 PM
I've decided this must have to do with security issues--re: these posts
https://duc.avid.com/showthread.php?t=402632
https://duc.avid.com/showthread.php?t=409476
Problem is I could use a step-by-step procedure for this. Does anybody have links? I've messed up my system twice because I think the layout of the system preference page where you allow blocked extensions to be installed is confusing and possibly buggy. It allowed me to click allow even though the lock stayed locked on the bottom, and let extensions through anyway. Sort of bricked my computer twice in the process. Anyway, any guidance would be appreciated. I know there are some terminal commands, but that is even less clear.
thanks
Kevin
Old 04-13-2020, 09:50 PM
Hello,
Previously it worked fine with PT12.3 on OS10.12, this last test was with PT19.12 on OS10.14. I would have stuck with PT12.3 but it's not supported under OS10.14.
Hugh
FS : OWC Mercury Helios Thunderbolt PCIE enclosure Marc Hudson Buy & Sell 0 09-17-2019 09:25 PM
OWC Mercury Helios TB2 zion macOS 3 12-21-2016 03:30 PM
HD Native pcie helios chassis working on core i5 macbook pro chrissinger86 Pro Tools HDX & HD Native Systems (Mac) 1 10-31-2013 03:08 PM
FS-OWC Mercury Helios PCIe to Tbolt $300 elbaro Buy & Sell 1 12-17-2012 01:38 PM
