#3041
Re: my i7 Builds - opinion welcome
I'm not sure if the larger memory video-cards are a problem anymore, but I played it safe and went with the firepro.
003r/i7-930/LE 8.0.1 cs2 on xp |
#3042
Re: i7 Builds - Specs and Results
Ditto what ^^^^^he^^^^ said...
U want as much memory as possible goin to PT regardless of what bit OS ur running...
#3043
is Radeon video cards better for PT than Nvidia cards?
#3044
No
#3045
No sir, if you build your own i7 machine you should stick with NVIDIA. The 9800 is a good cheap card with full support. Or for a bit more the GTX 260 fills your screen with butter so your pixels just glide effortlessly.
The ATi builds get funky. My GTX 260 OC was ready to rock OOB, duel monitor too. |
#3046
Stay away from ATI. Go with NVIDIA. The forum at the site i frequent is full of crazy ATI work arounds. And you could go with the i7 860 and OC it a bit. It will ive you more money for RAM. Look at tonymacx86 for some good info on parts and installs. My build worked OOB and took a few hrs to slap together and install. ^_^
#3047
cool Count, thanks for the heads up.
#3048
ATI cards are not a problem with these builds.
Get your advice from the first post on this thread...the guys that put it together have thousands of posts here and a lot of experience.
#3049
What would be a stable but powerful vid card to run if one wanted the ability to run 3 monitors with this build?
#3050
Both pretty pricey....probably cheaper just to add another dual-head card.
Best Core 2 Series Desktops-Results and Specs | sunburst79 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2416 | 02-19-2013 07:49 PM |
new to pc builds | chazc080488 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 10-18-2011 07:10 PM |
any p45 builds | fofif5792 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-09-2008 12:47 PM |
OSX "builds" | Richard Barrie | Pro Tools TDM Systems (Mac) | 2 | 10-18-2004 08:37 AM |
