Old 04-04-2020, 05:15 PM
DBboy DBboy is offline
Default Pro Control - No metering in Ableton Live 10
Hello. I have an s1 and a Dock running on Protools with no issues. I occasionally switch over to Ableton for certain tasks and got the setup working except that Pro Control shows no metering. All soft keys/faders (hardware and virtual) switches work fine except for that. Am I missing a setup step or is this not working yet? Thanks!
Old 04-07-2020, 12:31 PM
Default Re: Pro Control - No metering in Ableton Live 10
Does anyone have any insight on this? I've been researching and can't find any information. Thanks!
Old 04-07-2020, 12:47 PM
reichman's Avatar
reichman reichman is offline
I'm not Eddie, but I strongly suspect the issue lies with Ableton. Contact them. Avid wants the third-party manufacturers to implement Eucon deeply (including things like meters).
Nathaniel Reichman
Supervising Producer – Re-recording Mixer
Dubway Studios
Old 04-07-2020, 06:26 PM
That is possible, although it 's not really using Eucon, just the (bridged) HUI protocol. It works on other control surfaces, so I was just wondering if anyone on here uses this setup and might have some insight. Eddie, any ideas? Thanks!
Old 04-07-2020, 11:57 PM
Oggy Oggy is online now
There was a problem with the midi driver for Eucon a while a go that resulted in HUI and MC implementation problems. Check the threads for those issues. Might be connected...
Old 04-08-2020, 10:44 AM
EddieJones's Avatar
You need to use Mackie not HUI...what have you got set in EUCON ?
Old 04-08-2020, 01:29 PM
Thank you for helping! Yes, the Eucon pref is set to Mackie. Everything else works great, just no metering at all.
Old 04-08-2020, 02:06 PM
EddieJones's Avatar
I found this on Alberton's site. look at the post at the bottom from an Ableton tech. Seems there are scrips in Live that can be edited to make the meters work. You might want to try pinging that guy.
https://forum.ableton.com/viewtopic....90259&start=60
Old 04-08-2020, 02:17 PM
Thank you Eddie! I will try that.
Artist Control & Ableton Live 73* Artist Series 4 06-08-2013 08:33 AM
Adding a Ableton Live 'Locator' button to MC Control transco Artist Series 2 09-05-2012 11:25 AM
Artist Control/Mix + Ableton Live 8 Plugins ingeniousp Artist Series 0 09-04-2012 08:53 AM
Digi 003 as hardware control surface for Ableton Live? bentropy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-02-2011 08:11 AM
will 002 control other apps..ableton live?? Thresholdproductions 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-12-2003 07:32 PM
