Old 04-01-2020, 05:39 AM
arche3's Avatar
arche3 arche3 is offline
Default can I rename 2019.10 and install 2020 to have both?
possible to have both installed?
Old 04-01-2020, 06:04 AM
reichman's Avatar
reichman reichman is offline
Default Re: can I rename 2019.10 and install 2020 to have both?
I've done this with countless Pro Tools installations and it has worked. I'm sure it will with PT 2020, too. A developer would point out that the cleanest way to switch between versions would be to trash preferences each time you switch. But try it out.
Nathaniel Reichman
Supervising Producer – Re-recording Mixer
Dubway Studios
Old 04-01-2020, 06:15 AM
JFreak JFreak is online now
trashing prefs mainly forces PT to rebuild plugin cache which may help in anomalies should there be significant change between stock plugin versions
Old 04-01-2020, 06:30 AM
arche3's Avatar
thanks guys!
Old 04-01-2020, 06:46 AM
Tim R. Tim R. is offline
Just head the warning when installing 20.3 (or do it first). You need to copy the workspace pref file to a backup location and swap it out to use your 19 version.
Tim Reisig
System 1: Pro Tools Ultimate 2020.5, HD Native TB, HD OMNI, S3/Artist Transport/Eucontrol 20.5, Rosetta 800 w/XHD card
Mac OS 10.14.6, 2018 Mac Mini 3Ghz i5, 32Gig RAM
System 2: Pro Tools 2019.12 (no Hardware), Mac OS 10.14.6, MBP (Retina 13in, Early 2015, 3.1Ghz i7, 16Gig RAM)
Old 04-01-2020, 08:22 AM
arche3's Avatar
Oh... I didn't do that. But its on my laptop not my studio computer. Ill make sure to do that for my studio computer.
Sent from my SM-G986U using Tapatalk
Old 04-01-2020, 08:31 AM
arche3's Avatar
Tried opening 2019.10 after I used 2020. 2019.10 said it is backing up workspace and creating a new workspace. Will see what happens when I go back to 2020 again.
Old 04-01-2020, 09:21 AM
arche3's Avatar
going back and forth between 2019.10 and 2020 works fine. I just deleted preferences with the Peter Gates app between each switch.
the database thing only seems to come up going from 2019.10 to 2020.
I didn't bother to backup that workspace database each time. I am not sure what it does?
basic folders tracks go away. routing folder tracks turn into Aux input as expected.
Plug-ins/PT 2019 (2020) Installation Question TDTPost Pro Tools 2019 4 03-20-2020 02:25 PM
New Avid Link 2020.1 - launched today 1/16/2020 marianna Licensing & Accounts 8 01-16-2020 11:43 PM
2019.10 Won't Install DrBiscuits Pro Tools 2019 17 11-15-2019 08:06 AM
Install pro tools 2019.10 over 2019.6? Clarkston Guy Pro Tools 2019 6 11-01-2019 08:12 AM
PT 2019.6 Install Problem lgreen100 Pro Tools 2019 8 08-24-2019 08:05 PM
