Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
  #21
Old 01-29-2018, 05:12 AM
TrackerLe TrackerLe is offline
Default Re: Massenburg Design Works MDWEQ5 crahes PTHD 2018.1
TOM@METRO
Which version of Windows 10 are you using...For me both aax DSP and native crashes PTHD 2018.1. And i tried everything... I moved every other plugin out of the Plugins Folder. So only MDWEQ5 is in the folder. Then i trashed preferences, so PTHD reinit the mdweq Plugin. The first time PTHD crashed when try to read the plugin at startup. Second time, it worked... But Protools still crashes, when i insert the plugin and its the only plugin i have in the plugins folder. So no other plugin could be the reason of the crashes...
Did you install the latest update of windows 10. The function update, which won´t be installed by Auto Update. (it was released end of december and windows popped up with the message that a new big update is downloadable)
I installed that one and maybe this causes the plugin to crash...
  #22
Old 01-29-2018, 05:51 AM
Neil H Neil H is offline
I'm on x1703
Sent from my G8141 using Tapatalk
Pro Tools 2019.5 Ultimate
Windows 10 Pro
Join the Facebook Pro Tools Windows User Group
  #23
Old 01-29-2018, 06:17 AM
abc1mce2's Avatar
abc1mce2 abc1mce2 is offline
As Tom@Metro said I haven't really had a problem with MDW thought I rarely use it but when I do it's usually the DSP version. Since I've read this thread I want to know exactly what is happening....I mean does it crash your system on session load or when it's instantiated on an insert or crash after a short time? I have a test session I'm going to work on and I'm going to place several MDWEQ5 on a couple tracks just to see what happens on my system. My problem is that damn Duende SSL Bus Compressor. If I can get the session to load, PT will crash during session close.
What is more relaxing then Music?
GigabyteX79-UP4 Rev 1.1
Xeon E5 2680 v.2. 10 Core cpu Windows10 v.1803
Avid HDX 2019.5 HD - 16x16 - 8x8x8 HD I/O - PT Dock - PT Control - AVID Artist Mix (2)
Universal Audio UAD2 Pci-E and Satellite USB Octo - Pci-E Quad - SOLO 610 - Twin-finity
Antelope Trinity - 10M
Grace Design M905
Bricasti M7 (2)
Lexicon PCM96
Burl B2
Dangerous 2Bus
Neumann KH805 - KH310
Yamaha NS-10M
Avantone Mixcubes
Etc, etc, etc.
  #24
Old 01-29-2018, 07:31 AM
Protools HD 2018.1 crashes immediately after inserting the mdweq5...It opens the windows crash window, that this software doesn´t work anymore and must be closed a report will be send to microsoft...
  #25
Old 01-29-2018, 07:53 AM
abc1mce2's Avatar
Won't be til tonight and or tomorrow when I'll have time to run a session test on this. Thank you for the info.
Grace Design M905
Bricasti M7 (2)
Lexicon PCM96
Burl B2
Dangerous 2Bus
Yamaha NS-10M
Avantone Mixcubes
Etc, etc, etc.
  #26
Old 01-29-2018, 07:55 AM
abc1mce2's Avatar
This is what happens if I try to load a session with the Duende SSL Bus Compressor on it without disabling all plugins at session load.
Grace Design M905
Bricasti M7 (2)
Lexicon PCM96
Burl B2
Dangerous 2Bus
Yamaha NS-10M
Avantone Mixcubes
Etc, etc, etc.
  #27
Old 01-29-2018, 09:06 AM
TOM@METRO's Avatar
TOM@METRO
I run winver 1709 with latest updates. The issue here with MDW was not so much crashing, but constant errors.
Be sure you have turned of all CPU throttling and c-state options in bios. There are some systems that will run with increased stability when Hyperthreading is also turned off. Have you tried any of this?
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2019.5 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
  #28
Old 01-29-2018, 02:01 PM
I tried following... Disable VT-d and Hyperthreading... no luck still crashing...
How do i turn off CPU throttling?...
I made a backup and restored my pc... It installed the latest version of windows...
It was a clean install... The only programs, i have installed, were PTHD 2018.1 and MDWEQ5... So it is a clean windows without any other software... Still crashing when using mdweq5...
The last trie is to revert from a old backup, where an old version of windows is installed. If its still crashing, then i don´t know, what to do...
Is Fabfilter Pro Q 2 a good alternative with the same quality of MDWEQ. Then i will accept, that i paid 600$ for nothing, but i have a new goto eq...
  #29
Old 01-29-2018, 03:58 PM
TOM@METRO's Avatar
It may be called Turbo Boost. And all C-State needs to be disabled.
Sonnox eq with the Massenberg option is not a bad thing. And yes, I do like FabFilter.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
  #30
Old 01-29-2018, 05:35 PM
Now i reverted to an old Windows Version 1703...and installed PTHD 2018.1
Now the plugin crashes PTHD with the error message
Access violation occurred
cannot read 0x000000000000
So strange, I swear it worked and i did not change my system or anything.
Every other plugin works with no problems... I have the Sonnox Eq with GML and it works fine...only the mdweq5 crashes PTHD and i don´t know why...
I never changed something in the Bios... Every Hardware Test passes with no error... I am really crazy now, cause i reverted the pc to the state, it was shipped and back then the mdweq5 worked, but now... It doesn´t matter, what i do... It crashes Protools with an error message...
The GML Option for Sonnox isn´t like the mdweq5... But i am off now.. I will purchase the Pro Q 2, but it has no aax DSP...
Man i am desperated... WTF
My Machine UD4 X299 Core i9 14 Cores 64gb Ram HDX and 1080TI and only SSDs...
FS: Avid Massenburg Design Works MDW EQ5 AAX DSP/Native License Neil H Buy & Sell 0 08-08-2016 02:24 PM
Massenburg design works users, can you test 4 me crizdee Pro Tools TDM Systems (Mac) 12 02-05-2006 12:01 PM
Massenburg design works users, can you test 4 ZEUSS ProControl, Control|24, Command|8 3 01-28-2006 07:55 AM
Massenburg design works users, can you test 4 me sirpucho Pro Tools TDM Systems (Mac) 0 01-14-2006 11:42 AM
DIGI please design us a current config that works digi2000 Pro Tools TDM Systems (Win) 6 12-14-2001 09:24 AM
