Unable to record signal - Native Instruments (Kontakt)
I've watched some videos to solve this, followed basic stuff from Universal Audio Apollo X4 forum, as expected nothing very useful from NI themselves.
Wonder what I may be doing wrong: I set an Instrument track in PT (stereo), select an instrument in Kontakt, I just want to record it live, I *hear* the instrument, I *see* signal in PT (moving fader as I play), of course I arm both the track and transport bar, I hit play, but I end up with an empty track - it's tracing a colored track but nothing records there, nothing playback after. I've been using succesfully AIR instruments in other projects without any problem; in this one, I do have a ''Boom'' track. But Kontakt: no way I can get the track printed!
Rob ____________________ |
Re: Unable to record signal - Native Instruments (Kontakt)
So after you record on an instrument track using an air instrument, if you switch the plug in to Kontakt and load a selection, it doesn’t playback then either? Make sure you also change the VI assignment at the top of the track view. What else have you tried? Recording MIDI on an instrument track shouldn’t have anything to do with which VI you have instantiated.
PT 2024.3 Ultimate HDX, Dual Slate Raven MTi2, HD IO 16x16, Mac Studio M2 Max on Sonoma, 64GB RAM, 4 TB & 8 TB external SSD NVMe drives, Neve 1073OPX(2), Slate VSX, Focal Solo Be6, Roland V-Drums, DW drums, too many VI’s and plug ins to mention. |
To the op: Are you using the latest version of Kontakt 6? Check with NI's Native Access to make sure. |
Sounds like I can get it to work. Now facing another issue trying to create 16 stereo outputs and just getting surround outputs... Will post a different thread.
Dell XPS 15 Windows 10 Pro Tools 2020.11.0 Focusrite 2i2 interface |
Can you open the MIDI edit window on the VI track and manually insert notes? Does that playback with the VI sound then?
Native I Kontakt in Pro Tools: signal is there, nothing records! | lanstrad | Pro Tools 2020 | 0 | 04-10-2020 03:13 PM |
Native instruments Kontakt | YYR123 | General Discussion | 11 | 06-21-2015 05:52 PM |
Native Instruments Kontakt, Guitar Rig etc - AAX 64 bit? | yeloop | AAX Plug-ins | 2 | 08-16-2013 06:36 AM |
Native Instruments Kontakt | ebrowne | macOS | 1 | 07-26-2012 06:51 PM |
Native Instruments Kontakt! | Barhab | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-30-2003 12:21 AM |
