Old 05-30-2008, 03:02 PM
jacobfarron jacobfarron is offline
Default TL Space TDM Plugin causes Command 8 to lose communication
Got a Command 8 to demo... it works as normal until I open, modify settings, or close TL Space TDM plugin. I notice the USB light goes off on the Command 8. Only TL Space seems to cause the problem.
I'm using a 1GHZ Dual G4, 2 gigs of ram, Pro Tools HD (1 core, 1 process) 7.4cs4, 192, SYNC IO, Mac OS X 10.4.11
Have tried various USB ports and hubs, including disconnecting the keyboard and mouse, deleted preferences, etc. Power cycling the Command 8 fixes the problem - until I try to use a TDM plugin again.
Any ideas?
Here's a version list:
Fri May 30 17:55:01 EDT 2008
Pro Tools Version
__________________________________________
Pro Tools HD.app
7.4cs4, Copyright 1991-2007 Digidesign, A Division of Avid Technology, Inc.
Plug-In Versions
Analog_Channel_LE.dpm
3.2x17, Copyright 1998-2007 McDowell Signal Processing, LLC
BF Essential Clip Remover.dpm
7.3, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc.
BF Essential Corr.dpm
BF Essential Meter.dpm
BF Essential Noise.dpm
BF Essential Tuner.dpm
7.4, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc.
Broadband Noise Reduction LE.dpm
Broadband Noise Reduction TDM.dpm
Chorus.dpm
Chrome_Tone_LE.dpm
2.2x17, Copyright 1998-2007 McDowell Signal Processing, LLC
Click.dpm
CompressorBank_LE.dpm
4.2x17, Copyright 1998-2007 McDowell Signal Processing, LLC
D-Verb.dpm
DigiReWire.dpm
Dither.dpm
Dynamics III.dpm
7.4cs2, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc.
EQ III.dpm
Elastic Audio.dpm
FilterBank_LE.dpm
Flanger.dpm
Focusrite d2.dpm
Focusrite d3.dpm
Funk Logic Masterer.dpm
IXL Level Meter (H).dpm
IXL Level Meter (H) v1.3x0, Copyright 2006 Roger Nichols Digital, Inc and Elemental Audio, Inc
IXL Level Meter.dpm
IXL Level Meter v1.3x0, Copyright 2006 Roger Nichols Digital, Inc and Elemental Audio, Inc
IXL Multimeter.dpm
IXL Multimeter v1.3x0, Copyright 2006 Roger Nichols Digital, Inc and Elemental Audio, Inc
IXL Spectrum Analyzer.dpm
IXL Spectrum Analyzer v1.3x0, Copyright 2006 Roger Nichols Digital, Inc and Elemental Audio, Inc
IXL Statistics.dpm
IXL Statistics v1.3x0, Copyright 2006 Roger Nichols Digital, Inc and Elemental Audio, Inc
IXL Stereo Analyzer.dpm
IXL Stereo Analyzer v1.3x0, Copyright 2006 Roger Nichols Digital, Inc and Elemental Audio, Inc
Invert-Duplicate.dpm
L2007 Mastering Limiter Demo.dpm
"1.3.3d, Copyright (c)2006-2007 Steven M. Massey, All Rights Reserved."
LoFi.dpm
ML4000_LE.dpm
1.1x17, Copyright 1998-2007 McDowell Signal Processing, LLC
Mod Delay II.dpm
Multi-Tap Delay.dpm
Normalize-Gain.dpm
Oxford SuprEsser.dpm
v1.0.0 Oxford SuprEsser, Copyright 2008 Sonnox Ltd
Ping-Pong Delay.dpm
Pitch.dpm
RNDigital
RectiFi.dpm
Reverse-DC Removal.dpm
Revolver_LE.dpm
1.2x17, Copyright 1998-2007 McDowell Signal Processing, LLC
SciFi.dpm
Signal Generator.dpm
SignalTools.dpm
Sonalksis Free-G Mono.dpm
1.08, Copyright 2006 Sonalksis Ltd.
Sonalksis Free-G Stereo.dpm
Stereo Mixer.dpm
Structure.dpm
1.0.5316 Copyright 2007 Digidesign, A Division of Avid Technology, Inc.
Surround Mixer.dpm
Synth_One_LE.dpm
TL Space.dpm
Time Comp-Exp-Pitch Shift.dpm
Time Shift.dpm
7.4, Copyright © 2005 by Digidesign, a division of Avid. All rights reserved.
TimeAdjuster.dpm
Trim.dpm
VariFi.dpm
VocALignASX.dpm
2.9.7, Copyright 1995-2008 SynchroArts Ltd.
VocALignPT.pdf
Xpand!.dpm
1.0.2.6063 Copyright 2008 Digidesign, A Division of Avid Technology, Inc.
bombfactory BF76.dpm
Plug-Ins Unused Versions
Channel_G_HD.dpm
Dynamics II.dpm
EQ II.dpm
Stereo Dithered Mixer.dpm
Surround Dithered Mixer.dpm
Toolkits and Digitranslator Versions
Music Production Toolkit is not installed
DV Toolkit 2 is not installed
Digitranslator 2
7.4, Copyright 1991-2005 Digidesign, A Division of Avid Technology, Inc.
Digitranslator 1 is not installed
Old 06-12-2008, 05:17 PM
Default Re: TL Space TDM Plugin causes Command 8 to lose communicati
I took the Command 8 back to the dealer. I successfully used an Alphatrack without any problems. Now, I'm trying to use a Mackie Universal Control and have the same problem. Loading TL Space TDM causes Pro Tools to loose communication. Any ideas?
Old 06-16-2008, 05:59 AM
NickH NickH is offline
There is CS1 update for TL Space..
Try That.
Cheers
N
“It’s because you touch yourself at night... ”
System Specs
Old 06-20-2008, 09:54 AM
Thanks for the tip, but it looks like CS1 is for windows only. I'm talking with Digi on the TDM forum.
where is the command+space gone ? groovebrother Pro Tools TDM Systems (Mac) 14 11-27-2012 02:16 PM
X-Mon/D-Command Communication Problems chaosmonkey ICON & C|24 3 10-16-2012 02:18 AM
Constantly Losing Communication with Command 8 minister ProControl, Control|24, Command|8 18 03-11-2011 09:13 AM
I lose command focus when I switch spaces Sunzate 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-01-2009 09:50 PM
Command 8 Midi communication error doctorbrain ProControl, Control|24, Command|8 0 12-28-2006 06:41 PM
