Old 10-12-2018, 03:24 AM
2tallmen 2tallmen is offline
Default Artist Control and Logic Pro X
So this has been working brilliantly for the last 5 years.
I have an Artist Mix and an Artist control (Euphonix versions). The Artist Control keeps failing with Logic. It starts working fine then the faders on both surfaces flick up and down then the Control defaults back to the Avid logo. The Artist mix keeps working fine.
All firmware is up to date and I'm using the latest Eucon. I've tried going back to earlier versions but I still get the same issues.
Both work faultlessly with Media Composer.
Any one else have these issues?
Old 10-13-2018, 01:17 AM
EddieJones's Avatar
Default Re: Artist Control and Logic Pro X
This sounds like a hardware issue. Things to try...new network cable, switch the power supplies around, put the network cable into a different port on the network switch.
Avid Artist Control + Logic problems. matthihat Artist Series 4 02-03-2019 12:37 AM
Logic X & Artist Control lekareiz Artist Series 0 08-09-2016 08:54 AM
Logic X and Artist Control BenZenium Artist Series 2 08-08-2014 04:43 AM
Artist Control has no support for Logic X, or OSX Mavericks romanoffski Artist Series 20 07-11-2014 12:26 PM
Touching Artist Transport Freezes Up Artist Control in Logic sonofmack Artist Series 1 03-13-2013 08:22 PM
