Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 02-17-2021, 06:37 AM
Talisker Talisker is offline
Default How can I change the default track routing ?
I never did this, I hope I don't feel too dumb when I get the answers ;-) Here's the thing: I changed from bouncing to printing a master track inside the session. So now I want new tracks to be routed automatically onto the Aux that Is now my master bus instead of going straight out on my monitor output. I don't seem to be able to find that on my own.
thanx in advance
Mac Mini M1, 16 GB Ram, OSX 10.181.1,Focusrite Scarlett 18i20,Behringer ADA 8200,Pro Tools 2022 2xGlyph hard drive 750GB
Old 02-17-2021, 06:49 AM
Default Re: How can I change the default track routing ?
Can't be done that I know of.
Jack
QAPLA!
Old 02-17-2021, 07:32 AM
ChuckS ChuckS is offline
In I/O setup try changing the 'Default Output Bus' in the Bus tab to the bus you use for the aux.
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Old 02-17-2021, 07:33 AM
JingleDjango JingleDjango is offline
You can set a default output path in the i/o settings window.
Old 02-17-2021, 08:27 AM
I tried that already, but you can only select physical outputs of your interface , not internal busses....unless I made a mistake
Old 02-17-2021, 08:37 AM
It's in the Bus tab, not the Output tab - Default Output Bus.
Old 02-17-2021, 09:33 AM
Still does not work, I can select my bus there but after the that, it still reads "monitor out". Or is there another mistake I make ?
Old 02-17-2021, 09:39 AM
It won't change existing assignments, but any new track will be assigned to the selected bus. You'll need to change all the existing ones manually.
Old 02-17-2021, 11:45 AM
Track Presets and Session Templates are the solution for this
Old 02-17-2021, 12:35 PM
Ben Jenssen's Avatar
This is a bug, I think.
I have thought about this, as I would like my new tracks to default to an internal bus, but I never got around to exploring it.
Anyway, I just found that after setting "default bus output" in I/O busses page, even if it still says "Output 1-2", any new tracks I create will output to a bus. Not the bus I wanted, on first try, but it seems it is possible, though the I/O setup defalt will always say "Output 1-2".
Basic Routing Folder Default Jkoebe Pro Tools 2020 19 02-08-2021 08:17 AM
Change default track height? itsjustmeee123 Pro Tools 2020 1 04-07-2020 07:46 AM
Change Default Track View Mode migueldgoncalves Pro Tools 2018 2 01-15-2019 09:30 AM
HELP! Is there a preference in PT to change default IO subpath routing creation? bassmagnetic Post - Surround - Video 1 08-09-2017 04:03 PM
Can I change the default output on a new track? jrs320 Pro Tools TDM Systems (Mac) 2 10-23-2005 07:10 PM
