PT 2020.12 and Big Sur
My Mac Mini is sceaming for Big Sur as I didn't upgrade from 10.14.6 Mojave, has anyone gone to the Darkside yet does PT work ok?
Thanks Bayno
Pro Tools Editor, Producer, Mixer and Masterer since 1998 |
Re: PT 2020.12 and Big Sur
It’s not supported yet on Big Sur but I have been forced to install it on some systems running a Big Sur. Didn’t have any issues. You can give it a shot but unless there is a specific reason why you need Big Sur my recommendation would be to wait until it is officially supported.
Upgrade to Catalina (that's supported) and wait for support for Big Sur.
"May work" is not good enough ... |
The bigger question is will your plugs and VIs work. Several run Pro Tools on Big Sur with no to few issues.
What happens in Vegas, we make happen... |
Sweetwater has a compatibility chart they are maintaining:
https://www.sweetwater.com/sweetcare...atibility-List You'll want to check plugs, vi's, interface drivers, etc... Not all vendors are compatible yet.
5K Retina 27" (2020) iMac OS 13.6.5 Ventura 3.3 GHz 6-Core intel Core i5 AMD Radeon Pro 5300 4 GB 64 GB 2667 MHz DDR 4 Internal 2TiB SSD Pro Tools 2024.3 EuCon 4.8.6.41 / 2023.11 UA Luna UAD 11 UA Apollo Twin X Avid S1 / Fire10 - 21.8.1.0 PreSonus DigiMax FS 8-input ADAT Dynaudio Monitors PreSonus Temblor 10 Sub Check my Music out here: Paul G YouTube Paul G Bandcamp |
www.dpksound.com Last edited by dkrz; 02-14-2021 at 10:42 AM. |
Generally speaking anything that worked well in Catalina should also run in Big Sur, but the big exception here are low level hardware drivers. You may try but probably need to wait a bit for support.
what about anything in mojave that worked? will that work in Catalina?
We had to upgrade one of our boxes due to another software issue and the only problem I have seen is with the import function. Files do not show up so we have to drag everything into the session itself. Not really a biggie for most here but im OCD so its killing me. Even typing this is driving me to drink. Definitely can't blame Avid.
Bob Sandifer Bob Sandifer - Mixing and Mastering - Somewhere in Macon Georgia 404.783.9103 / [email protected] Greatest Achievement: I killed a Chimporangapuss with a sharp stick. I am now KingCoochieTomTom!.....with a gooey sharp stick. |
For starters check Security & Privacy > Full Disk Access |
How to uninstall Pro Tools 2020.11 and revert to 2020.9.1 | ArKay99 | macOS | 10 | 02-27-2021 02:41 PM |
Pro Tools 2020.5/2020.3 Compatibility with Catalina 10.15.4? | derrickhou | macOS | 4 | 07-26-2020 07:46 AM |
Avid Control App Rollback (2020.5 to 2020.3) | budster | Avid S1, S3, Dock and Control App | 2 | 06-09-2020 11:01 AM |
Pro Tools (2020.3) on MacBook Air 2020 compatibility | pellekuipers | Pro Tools 2020 | 1 | 04-04-2020 08:01 AM |
New Avid Link 2020.1 - launched today 1/16/2020 | marianna | Licensing & Accounts | 8 | 01-16-2020 11:43 PM |
