Old 06-01-2011, 09:47 PM
dmock66 dmock66 is offline
Default Main Outs
Does anyone have intermittent problems with the main outs not working? I found where I can set the Amp Outs - but the Main Ous should always work, right?
Old 06-02-2011, 07:08 AM
singtall singtall is offline
Default Re: Main Outs
as far as i know they should. i may have to go back and read the manual though. i never use the amp outs, so i'm not sure. i thought the main outs (xlr) were supposed to always be on though.
Old 06-02-2011, 08:56 AM
Thanks for the response Ross.
That was my understanding as well - the Main Outs are always active. I hooked up the XLR to the left Main Out before turning the 11R on. I did this twice - once at church, once at home. Both times, no sound. After scrolling through all the menu options, reading the manual and searching the forums I tried the Main Out again - this time plugging in after the 11R was already on - and voila, it worked. Is there some odd "kill switch" that sliences the Main Out if you plug a cable in before powering the 11R on? That would seem pretty odd to me - but that is the only correlation I've made at this point.
Old 06-02-2011, 12:17 PM
Jefcity Jefcity is offline
The main outs can be muted. Did you check to make sure you don't have the main mute on accidentally?
Old 06-02-2011, 01:04 PM
I don't believe that was the case as it did work later - although it is also possible in my mad fury I did change that. Where is the mute setting, just so I know?
Old 06-02-2011, 01:39 PM
Stratus Stratus is offline
I've had this happen twice and have learned to check a few more things when setting up live. First, I had muted the main out in the studio with the 11R Window and forgot about it when I shut down so i had nothing when I set up live. You can unmute from the 11R going to USER OPTIONS -> Volume Knob -> SW 1 to toggle on/off. The other time, I had not plugged in my volume pedal and the volume level must have been set to zero when I shut down (I had Persistent Volume Pedal set). So again, when I set up I had nothing until I figured that one out. Both times, I worked through several cable changes thinking that might be the problem....now I know to check a couple other simple, but not obvious things.
Good luck!
Old 06-02-2011, 01:44 PM
I just got mine yesterday - used from Ebay. The previous owner may have had the Main Outs muted. I also may/may not have changed that setting over the 45 minutes to an hour that I spent pouring over settings. I'll have to check that to ensure it's set to not mute the Main Outs and test further.
Thank you for the input/suggestions - it's GREATLY appreciated!
Old 06-02-2011, 09:13 PM
Okay - I hadn't muted the Main Outs. However, I did notice that when I wasn't getting any output from the mains I also wasn't showing any input either. When I activated the tuner it was stuck on "F" regardless of what I did.
I tried moving the sampling rate from 44.1 to 48, which seems to fix it. Is there a problem with leaving it like that (assuming I'm using the 11R as a live modeler only)? I've not tested by not being plugged into the input at powerup - but that may also solve my problem.
Also - my serial number does not end in E.
Old 06-02-2011, 09:32 PM
Benoni's Avatar
Benoni Benoni is offline
Sounds like you may have a bad unit. Having to change sample rates is a classic sign. I would contact Avid and get a replacement unit shipped to you.
Brian
Windows 10 Pro 64 Bit
Pro Tools 2020
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Instagram
Old 06-02-2011, 09:52 PM
What needs to be fixed/replaced? What is the cost of something like that?
I am the second owner (that I'm aware of). I just got it off ebay this week. Do I still have any recourse in this situation - other than to try to return it to the Ebay seller?
Digi002 rack main outs vs monitor outs studiojb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-03-2012 07:46 AM
Problem with 002 main outs as well as head phone outs? wiseal1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-10-2009 11:36 AM
001.....Main Outs or Monitor Outs G. Klopfenstein 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-01-2004 08:07 PM
main outs vs. others freakuincy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-08-2002 06:54 AM
How can I have the monitor outs and main outs to the same input? voxpitch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-15-2001 09:16 AM
