Searching this forum for posts that have either "bounce to disk" or "-2015" in the subject or body (looking in the last year) results in no results, with out quotes you get every post.
using the search at the bottom of the page did get a hit but no luck from the "search" page. so I changed the title. Still the only hit was for someone who was having problems because of unsupported formats. This is a single video track with one insert edit. The section with the edit will bounce to QT, but not the whole film (23 min). I may try in sections and reassemble in QT or FCP. The reason I was looking is that EVERY time I try to bounce my current project to disk it stops in the final stage with the error " Could not complete the Bounce To Disk command because (-2015)". I know there have been BTD issues and I know there have been some in the last year and I'm sure someone else has been nailed by this error. If anyone recognizes this error would you please point me in the right direction. Thanks And Digi I use to be able to find things with search but I have to say that the last three or four times I have tried I got nothing use full and had to page back till I found the thread I was looking for??? |
Try using a short file-name, and change it to the correct name in the finder after the bounce.
Unfortunately Quicktime doesn't allow long file names. So it's not entirely a DIGI-bug, although I believe, DIGI could program it in such a form, that an error-message comes up before the bounce has gone through the whole length, which is not only annoying but of course extremely time consuming. Maybe that solves the problem. Timothy |
Thanks guys,
I tried 2015 and "-2015", if you put it in quotes you can use the "-", I was still having no luck. But the search at the bottom of the page was working. I'm still not getting the hits I know are out there. THe BTQT and BTD have both had lots of problems at times and were an issue with 7.3??? The last time I tried the bounce the name was "test" so I don't think long file names are the issue. About two weeks ago I bounced this same session to QT with no problem. I thought it might be the insert edit on the video track but I have done this before with no problems and as I said I successfully bounced that section of the session with no problem so??? I finally bounced just the audio (no problem) and dragged it and the original video into FCP and duplicated the insert edit (we extended a title card by a few sec) and out put that to QT. No problems, but a pretty wanky work-around. ----------- DIGI, PLEASE put out a list of error codes. It is VERY unprofessional to not do this. It might have been of no use being too general, but it might also have pointed out the problem. At the very least it would not be your fault that I wasted hours trying to find out what the hell the number meant - I still don't know, it's not listed anywhere. |
Strange Video Error -2015 | Jackdanny | Post - Surround - Video | 4 | 03-21-2017 02:34 PM |
2015 error when exporting a movie | RuffinMedia | Post - Surround - Video | 1 | 10-19-2010 07:09 PM |
Import Video error -2015 | matt connolly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-28-2009 04:57 PM |
Bounce To Disk ERROR -2015 | nehemiahmh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-26-2006 03:40 PM |
Error 87... I did a search, but still..... | Roy Howell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 12-22-2002 12:28 PM |
