programs to translate a .wav into midi
I am looking for a program that can turn an audio-file into a midi-file. I want to use this to get a drum-track better sounding, and to do some experiments. Do programs like that exist? And if so....are they free?????? [img]images/icons/grin.gif[/img]
What's that? - That's the machine that goes "pling". Bastiaan |
Re: programs to translate a .wav into midi
I think I'm totally misunderstanding your question.
Do you mean that you want a program that will use the .wav file as a sample which you can then trigger with midi data in order to "beef up" a drum track? I ask because I want to make sure that you know that a midi file isn't sound...to over-simplify, it's just on/off messages. For example, I use a Proteus sound module: it's just a storage bank of high-quality samples. I trigger the sound module to play a sample with midi data from my keyboard or from a software sequencer. So, did I understand you question right, or did you already know all this and I'm just talking out of my butt? [img]images/icons/grin.gif[/img]
XP2500+, a7v8x-x, 60/80G drives, pc2700 Micron, SIIG 3 port, win xp home, Radeon video, ADS/WD 120 FW drive, 002r PTLE 6.1.1 stable as can be. |
Basschair,
I DO know what midi is.... [img]images/icons/grin.gif[/img] what i want is that the hits in the wav-files will be transferred to midi-notes. That's all. I have several drum-tracks that i didnt record that well, and i want to replace them with samples from my samplecell card.
I know what you mean, but i don´t know of any programs that do this. I have to feed the audio to my D4 and then record the midi data that it spits out....
jorge |
It's called Recycle, made by Propellerheads (www.propellerheads.se). It's a program that will load a loop of any type (could be drums or even other instruments) and it will automatically slice the file into sections for each "attack" it finds, or you can manually slice it yourself. It will export the file which can be imported into Reason's Dr. Rex module. Otherwise, it will also save each slice as it's own wav file to be imported into any sampler.
Here's one:
http://www.akoff.com/music-composer.html Never used it so I don't know if it works. Do a general internet search for "pitch to midi" and you'll come up with a bunch more... that I've never used. The one above is Poly... most are mono. |
oops,
I think i didnt tell exactly what i am looking for.... I just give it another shot. I have this drumtrack that is played very nicely, but the quality isnt that good. I want to do it better. But it has to go back into teh song....and the song isnt recorded with a midi-click or something. Now i was hoping there is some program that will just read the audio on the track, and for every drum-hit, it will substitute a midi-note. Then later on i can take this midi-file, import into ptle, and assign a drumsynth to that midifile. I realise i have to pencil out a lot of stuff, but i dont mind....
jms40 is on the right track. I will try this program and let you know how it works!
Please do... I've been curious about these.
what about sound replacer?
Subject51 Producer / Composer / Remixer |
MIDI I/O port names.....please translate | megabraun | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-13-2009 09:17 AM |
Can I use MIDI from other programs? | goosefreak | MIDI | 6 | 03-25-2008 10:20 AM |
Best MIDI Sequencing Programs | FullFreq | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-01-2004 06:24 PM |
Midi nodes in other programs | Marketis12 | Pro Tools TDM Systems (Mac) | 0 | 08-11-2003 11:36 PM |
WAV to MIDI conversion (10 programs) : | DORUMALAIA | General Discussion | 4 | 06-16-2003 02:00 PM |
