Old 11-08-2001, 11:03 PM
east3rdst east3rdst is offline
Default Whats the difference between AUX & BUS
I almost wanted to post this under a different user name, but I just got my 01V and it's my first really powerful mixer. To be honest I don't really know what a AUX & Bus areor how there different. Thanks
Old 11-09-2001, 05:37 AM
Ben Jenssen's Avatar
Default Re: Whats the difference between AUX & BUS
Haven’t worked w/01V, but I’m shure it uses these consept the same way as in PT or any mixer:
A bus is an internal routing for tracks to send out of the mixer to tape or HDRec.
An aux (auxilary) output or input is also called "send" or "return", and is for sending some of the track signal out to an external effect and returning the signal.
Old 11-09-2001, 05:41 AM
DOUBLE EDGE DOUBLE EDGE is offline
We were all new at one time... an aux track is a couple of diff things so its purpose is for a couple of things. and aux track can be used to moniter sound coming from outboard gear like efx,comp, etc. or it can also be used to provide plugin efx to multiple audio track. for example if you want all your vox to be compressed the same, instead of putting a comp on each vox track you would send it the aux were you have the compressor, and that leads us to bus which is whut is used to carry the signal from your audio tracks to the aux track or like in the 1st example to the efx unit then back to the aux so that you can moniter it. ppl use aux track for more things then just that but me thats my purpose of an aux track. maybe more ppl can tell you whut kindda things they do with auxes and busses...
Mac Pro 2.66 - PT 7.3.1 cs2 -
Whats the difference between LE & M-Powered PT? Robbie2327 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-30-2008 05:56 AM
Whats the difference between v4.3 VS v5.0 session? grivel Post - Surround - Video 0 05-09-2004 07:19 PM
OT - whats the difference between the Beta 57/57a? shutupandshave 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-28-2004 01:30 PM
whats the difference a bad man sittin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-13-2004 11:44 AM
vst & vsti, whats the difference? halfguard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-21-2004 07:46 AM
