delay between two tracks
Hi, to anyone who can help, Im just after doing some parrallel compression, however I noticed after bouncing one of the tracks to disk, and after importing back to the session there was a slight delay between the two tracks, (there were quite a few plug-ins inserted on the bounced track!!) so appart from manually lining up the two tracks so they a running exactly, does anyone one of a way that the amount of samples 'out' so to speak can be worked out exactly? Im sure someone explained a way this can be done, and ive gone ang forgot, cant find anything on the web! If anyone knows what the hell im banging on about then cheers! |
Re: delay between two tracks
Good ol' plug-in delay. Gotta love it.
In a parallel comp scenario you can run a comp on both tracks, and just leave the original wide-open. Or you can calculate the actual amount of samples, and nudge if you're really that stressed for clock cycles. |
Pro Tools 9 Delay and Delay Compensation on Aux Tracks and Bussing | CNSound | macOS | 1 | 01-27-2012 11:10 AM |
Effects delay on tracks | willl3 | Pro Tools M-Powered (Win) | 5 | 07-22-2007 07:43 AM |
delay with audio tracks | michaelblount | Digidesign Hardware & Software | 0 | 02-05-2004 01:08 PM |
delay with audio tracks | michaelblount | Digidesign Hardware & Software | 0 | 02-05-2004 01:04 PM |
recording delay on tracks | superjim2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-27-2003 03:30 AM |
