Old 05-11-2006, 12:00 PM
Peter Groom Peter Groom is offline
Default Manipulating effects
HI there
Can someone tell me how to go about defining a point on the timeline where for instance an effect, be it eq or reverb etc needs to be removed. ie it is there then its not. or inded a point at which it appears.
Cheers
Peter
Old 05-11-2006, 12:14 PM
Kryst Kryst is offline
Default Re: Manipulating effects
Trying to clarify what you're looking to do.... Effect Automation? I think it would do what you want, and also it's able to let you tweak automate, too. So you can turn an effect up and down, not just one solid setting
Kryst
Slim Shady Slim Shady is offline
It's called automation, check your manual, or if you don't have one you can download a PDF here. To make an effect appear or dissapear completely, you should start by automating the bypass function of the plug-in.
Old 05-11-2006, 12:20 PM
These links are more direct. Thanks to spkguitar in the PT LE Windows area.
Page 533: General Automation info http://akwww.digidesign.com/support/...e.pdf#page=545
Page 22: Specific details
http://akwww.digidesign.com/support/...de.pdf#page=28
Kryst
Manipulating Midi Notes ahf Pro Tools 9 2 03-16-2011 09:02 PM
Manipulating Files in Pro Tools Tanneseph Pro Tools M-Powered (Win) 3 03-05-2011 02:21 PM
The Click and manipulating sub divisions. Monty_python 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 09-05-2009 03:28 PM
Time manipulating tools Tomio Broman Pro Tools TDM Systems (Win) 3 02-10-2009 11:55 PM
Manipulating Markers? Jsalam112 Tips & Tricks 2 04-17-2003 11:39 AM
