Old 02-19-2012, 10:17 AM
Mischdepp Mischdepp is offline
Default Batch fades no longer working in PT 10
I'm editing a voice over recording which is pretty low in quality - lots of background noise which I have to replace with quieter "room tone " passages.
Normally I would insert this quieter room tone in longer gaps in the recording and after that select the edited part and press "F" to add crossfades on all edit points selected. This function does no longer work in PT 10 - at least on my system. I tried to check/uncheck the fade options in the batch fade window but I can't bring ProTools to batch crossfade on a selection. Setting Fade in's/out's works nevertheless.
Any advice?
Matthias
Old 02-19-2012, 11:31 AM
Drew Mazurek's Avatar
Default Re: Batch fades no longer working in PT 10
Works fine here. Have you set your Default Fade in the Prefs?
www.drewmazurek.com
Old 02-19-2012, 07:58 PM
Where exactly would I do that? I have set fade defaults in the editing menu of the preferences but this doesn't help...
Old 02-20-2012, 05:31 AM
That's what I was referring to.
Have you trashed all prefs etc as mentioned in the basic troubleshooting threads?
www.drewmazurek.com
Old 02-20-2012, 04:10 PM
Yep! Did that but without any positive result.
Also tried older sessions I had not touched until upgrading to PT 10 - no way to batch fades...
Next step will be starting up from a clone drive hosting PT 9... will post results asap.
Old 02-21-2012, 05:47 PM
crowdog crowdog is offline
Is the keyboard focus on the edit screen?
___________________________________________
Mac Pro 2 x quad-core 2.8Ghz / 14GB RAM / OSX 10.6.8/ PT10.0.1 / 003R
Old 02-27-2012, 08:25 AM
It seems to work now
Haven't changed anything - not willingly I mean...
Will keep an eye on it and post in case the problem reoccurs.
Old 01-08-2013, 01:17 PM
mu-tron-kid mu-tron-kid is offline
Just noticed this isn't working in 10.3.3 !
Brian Dozoretz
Mac Pro, osX.10.12.6, PT 2018.3 HDX, 2 x Alpha/Deltalink
2 x iMac, osX.10.12.6, PT 2018.3 HD Native PCIe + HD Omni
iMac, osX.10.12.6, PT 2018.3 HD Native PCIe T-Bolt expansion chassis + HD io, Artist Series Mix x 2, Artist Series MC Transport
VENUE SC48 3.1
SSL Duality via ipMIDI / ∂elta Automation Plug-In
Help ME - Batch Fades Bug DJ Stretch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-01-2009 09:32 AM
Fades prefs vs. Batch Fades (or beating a dead horse) Starcrash Post - Surround - Video 2 09-23-2008 04:40 PM
create fades batch fades issue pt le theom Tips & Tricks 4 07-24-2006 10:46 PM
Batch fades? ustrata 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-06-2003 05:15 AM
Batch Fades thin ice Tips & Tricks 2 05-17-2003 04:40 PM
