Old 05-15-2007, 01:11 PM
Bellboy Bellboy is offline
Default Left side of monitor goes out
Hi fellow recorders. I'm running HD 2. Has anyone had this problem? While listening back to some recorded material the left side of the stereo went out. It didn't effect the signal going out to the singer who was recording. Signal appeared to be coming out of the 192. When I powered down the C24 it would fix it for a little while, but then it would happen again. When I re-booted the whole system it fixed it for the rest of the day. But it still happens now and then. I did get some sort of ethernet message once when I powered down the C24. Thanks for your help.
Old 05-25-2007, 06:52 PM
mscotts22 mscotts22 is offline
Default Re: Left side of monitor goes out
I have the exact same problem with my C24, it needed new monitor section cards. Contact Digi to get it repaired.
Playback only out of left side PYROAZMB Pro Tools 9 1 03-06-2012 12:40 AM
Sound coming from only right or left side? Chronobot 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-28-2011 03:43 PM
I only get sound out of left side of headphones msgood 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-21-2009 09:16 AM
001 Out levels Left side hot? ajazzie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-30-2003 10:12 PM
Lost left side audio! lgs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-15-2000 08:58 AM
