Old 07-03-2018, 09:29 PM
loftus loftus is offline
Default Re: Cannot import audio track via Import Audio menu item
I had this problem but I can get around it by dragging the file I want from the desktop into the multitrack window and onto the track I want it on
Old 07-04-2018, 10:11 AM
CamM CamM is offline
I had this issue (the only issue (sadly)) on 12.5.2 on high sierra 10.13.4. I knew it was unsupported, and the o/s was also unsupported, but I figured I hadn't bought a version of Pro Tools for about 5 years so jumped on the subscription - import audio works fine now with 2018.4 on 10.13.4.
Old 07-04-2018, 07:20 PM
Dustycoats Dustycoats is offline
Me too!
Could not complete the Import Audio command because Assertion in "/Volumes/Development/158347/ProTools/NewFileLibs/Cfd/MacOS/Cfd_ImportAudioDialogMacOS.mm", line 603.
Disappointed by protools again....
Old 07-10-2018, 02:31 AM
Mario75 Mario75 is offline
Updated to 2018 from 12.5, and now works well, was since I had updated to high sierra that started to happen ... So there you go, with 250$ update you solve it... If that is from any consolation :)
Old 12-13-2018, 10:10 AM
ckwalldorf@gmail.com ckwalldorf@gmail.com is offline
Same problem with 12.5 and High Sierra. I had the problem on another configuration but an upgrade solved it. Now it's back.
FYI, you can drag the audio file from your desktop directly into the project and that works. Annoying, but a pretty easy workaround.
Import audio files on one track using Import Audio Command Sir Hannes Pro Tools 12 6 01-16-2018 02:50 PM
9.0.5 audio import menu missing characters sidi1 macOS 2 09-13-2011 05:53 AM
Import Audio To Track- Preview Audio Does Not Work Curve Dominant 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-15-2007 08:02 PM
import audio is greyed out on the file menu sselrahc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-23-2003 05:47 PM
Why does the 'import audio' menu take sooo long! mishmash Pro Tools TDM Systems (Mac) 24 01-25-2003 06:36 AM
