Go Back   Avid Pro Audio Community > Pro Mixing > System 5
Old 01-05-2020, 11:07 AM
Ulf Ulf is offline
Default Fader follow selection on S5 Avid MC Pro Pro?
Is it possible to have faders following selection on the Avid MC Pro?
I have an Avid MC Pro 5 with 4 faders! Is it possible to have the faders following the selection you do on the touch screen???
Best regards Ulf
Mac Pro 2x3,46 GHz 6-Core OS 10.13.6
System 5 SC264D, CM408x3, CM402, CM401
AM713, MA703, ML530, MC524, FC726
ProTools Ultimate 2019.5, Avid MTRX
Old 03-13-2020, 12:39 PM
niekbeem niekbeem is offline
Default Re: Fader follow selection on S5 Avid MC Pro Pro?
From p46 in the User Manual:
Press the Wave and Chan Select keys simultaneously to assign a track to a strip. This technique is called Direct Assignment.
From there you can select "follow attentioned channel" (or something, I'm not behind my MC Pro at the moment, but I think it's on top of the channel-list which appears) , which would let you control the fader of your attentioned channel. There is also an option in MC Pros' prefs called "Attention most recently selected track", which needs to be switched on in order to make the link between a selected channel in your DAW and a attentioned channel (=fader) on the surface of your MC Pro.
Please keep in mind: there can be multiple channels selected, though there can only be one attentioned (=brought to the surface and the 8 rotaries). The selected channels are represented as white squarers on the Solo/Arm/Mute/Select-matrix on the MC Pros' touchscreen, and the attentioned channel is shown below the Solo/Arm/Mute/Select-buttons in a blue circle and a yellow number. the "Wave" key next to each fader is the key with which you can attention a channel. The ChannelSelect-key only selects the channel(s) in your DAW.
On my system I've got both options "Attention most recently selected track" and "Select most recently attentioned track" switched on in order to have a selected channel linked to the attentioned channel and vice-versa.
Niek/ Amsterdam.
Pro Tools Ultimate 2023.6 / Nuendo 12 / Logic X / WaveLab 11
MacPro 5.1: 12Core 3.46GHz Intel Xeon/ 48GB RAM/ Mac OSX 10.14
MacBook Pro: 2.9 GHz Intel Core i9/ 32 GB RAM/ Mac OSX 10.14
MetricHalo ULN8 + 2882 / RME HDSPe MadiFace
Euphonix MC Pro
Setting to make plugin selection in DAW follow channel selection? polyh3dron Avid S4/S6 16 08-23-2021 09:23 PM
window follow track selection broken in 19.9.1 Frank Kruse Artist Series 6 11-20-2019 02:57 PM
Pan and plugin windows follow selection GuidoHelbling Post - Surround - Video 13 09-25-2014 01:38 PM
C8 Track selection Follow daslicht ProControl, Control|24, Command|8 4 01-11-2011 06:11 AM
mix window does not follow c24 send selection Serge Perron ICON & C|24 0 10-19-2010 06:37 PM
