Is there a midi pad for drum recording?
Hey Guys,
Instead of using my keyboard for doing drum recordings (strike, ez drummer), are there drum pads that hook up through midi to do this instead? being a drummer that would be much more fluid. If so, what are some good ones for low cost? appreciate advise!
TDub Digi002 R with Command 8 - PTLE 8.03 Intel Quad Q9550 Asus P5Q Pro Win XP 4GB |
Re: Is there a midi pad for drum recording?
I do drum tracks with both a Roland TD-10 kit and an M-Audio Trigger Finger sitting on my desk. Both work great with ezdrummer and SD2. The Trigger Finger allows for custom pad assignments so I made a page with 2 pads assigned to snare and each of 3 toms, and that allows me to record rolls and fills that sound real(try doing this with a single finger pad). In any case, any midi pad trigger should be able to work fine(even the Korg Nano at $69). BTW, the Roland TD-10 kit triggers almost everything exactly correct, right out of the box(with ezdrummer and SD2). I did need to search around the midi note assign(on the TD-10) to get an extra pad to trigger a cowbell or cross-stick).
There is also the Akai MPD18, which is a pad controller (no sounds built in) like the M-Audio Trigger Finger that Albee mentioned.
Also, the M-Audio Axiom keyboard series combine keyboards with 8 pads built in. |
Nice! So i assume any midi electronic drum kit would work as well?
Some programs are better at working with eKits than others... the best for eKit support are: BFD2, Superior Drummer 2.0 and Addictive Drums 1.5
Rail
I've been having surprisingly good luck with the Korg NanoPad. For the price, the NanoPad is astonishingly sensitive, and highly configurable. It totally outperforms the pads on the M-Audio Axiom and Novation Nocturn controllers which I find fairly stiff even after a year of use.
One of my partners here in the lab uses a really nice Roland V-Drum setup for serious tracking, but we've both gotten a lot of use from the NanoPad. Don't be turned off by the diminutive and somewhat toy-like appearance of the NanoPad. For less than $50 USD, these little slabs are a real kick and well worth it. We were originally talking about splashing out for one of the bigger, more expensive pad controllers - no regrets here. NL |
My favorite is the AKAI MPD 24. Each pad has 16 velocity steps, it's pressure sensitive and has 16n unique channels and 4 pad banks for each. I've had it for a year or so and love it. The MPD 32 is a little better (features), and the MPD 18 is cheaper, but it's just the pads.
Appreciate all the advice here guys! Very cool.
So last night i bought the Nano. Haven't got a chance to use it, but thought it was good price to try out before i spend too much. Make sure i use it enough, then would upgrade if not satisfied with it. Glad to hear some good feedback on the Korg again, appreciate all the feedback!
Nick
Core i7 920 OC'ed @ 4.0 GHz (200 X 20) 12 GB Patriot Viper Extreme Asus P6T OCZ Agility 64 GB SSD Hitachi 1TB 32 MB HDD WD Caviar Black 500GB Saphhire HD 5850 3 x 20" monitors Eleven Rack w/ ERXP Fender Super Champ XD Marshall JCM2000 DSL100 Silver Edition W/ Silver Jubilee Cabinet |
You could consider a midi keyboard controller too. I have the Korg Nanopad but like the Akai LPK25 instead. It can serve double duty - drum trigger and regular midi keyboard.
The drum layout is usually pretty standard on the keyboard. The Kick is C; the snares D & E; toms G, A, B etc. You could also troll ebay for some of the "toy" type midi triggers. I have the Yamaha DD-55 and occasionally find it useful. It can be had on ebay for well under $100. Check out youtube for videos of people playing these "toys."
____________________________________ Home Build: Core i7 920/Gigabyte EX58-UD3R/6Mb Ram Mbox2/MboxMicro ProTools 8.0 |
Seeking Midi Drum Recording tips | cruisemates | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-27-2009 07:55 PM |
electronic drum kit recording setup(MIDI) help!!!!!!!!!!!!!! | moon1pulse | MIDI | 5 | 06-13-2007 12:36 AM |
recording midi drum machine style | Daddijonez | Pro Tools M-Powered (Win) | 3 | 11-07-2006 10:17 AM |
midi recording drum tracks | elv1s1sal1ve | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-30-2005 08:34 PM |
MIDI drum loop recording | MrMike | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 02-04-2002 06:51 AM |
