Old 11-11-2002, 09:48 AM
LATablette LATablette is offline
Default Help! Error 9128 "Your\'e running out of CPU power. Take out some plugins to free..."
I keep running into this error. I did not run into it before I went to Win xp (except when I was REALLY taxing the system) But now, with just one or two plugins, it is giving me this error a lot. I am running a quicktime file in the session (and yes, I have turned the QT track to "Blocks) But it happens even when I am not playing the QT file. I have tried turning everything that is running in the background off--to no avail. My buffer is set to 1024. any suggestions?
I have a P3 800Mhz, 256 RAM, win xp--with audio and video coming off a seperate drive from the system drive
thanks!
Old 11-11-2002, 10:01 AM
Mr_Seven Mr_Seven is offline
Default Re: Help! Error 9128 "Your\'e running out of CPU power. Take out some plugins to free..."
I know it's obvious but you need a faster system.
Darren Valen
Cyberdream Studios
Old 11-11-2002, 10:31 AM
yeah, I know, but why was I not getting these errors before when I was on win 98. I'm thinking maybe I don't have all my settings right (in iether xp or in PT when I re-installed it)--any suggestions?
Old 11-11-2002, 10:45 AM
gracepoint gracepoint is offline
Yeah, I'm getting that error alot too since moving from Win98 to XP Pro. It sucks because I got way more plugins in Win98. I'm using a Pentium 3 1ghz in my machine. One thing I did was switch the buffer size hit play wait and the error pops up, then switch it again and hit play and it usually works. Pretty sad though, because I have almost no RTAS plugs running in my session I copied virtually everything over to Audiosuite and the error almost never fails to appear. [img]images/icons/mad.gif[/img]
Old 11-11-2002, 11:03 AM
Platinum Sounds Platinum Sounds is offline
You may also try a Hardware profile running only the bare necessities required for your desired audio applications (Protools, etc)...
Also, I would possibly run a defrag on the system drive and try to do that on a regular basis (XP requires more HD space to run efficiently).
Hope this helps
[img]images/icons/smile.gif[/img]
Old 11-11-2002, 02:03 PM
Sounds like a common problem. Think I might wait until PT 6 is available, and then get a G4 dual proc. Thanks!
Old 11-11-2002, 03:32 PM
JMS40 JMS40 is offline
Hi LATablette-
Guess you can geta a Mac if you'd like. [img]images/icons/smile.gif[/img]
My old P3 800 system did better or equal on the DaveC than the G4's posted.
Still, as stable as that setup was for me, it was power limited. There's a world of difference between it and the XP 1700 im playing with now.
You're asking alot of a P3 800 running PT with Quicktime files, which is something you weren't doing in 98.
Just some random thoughts.
Good luck-
Old 11-11-2002, 06:38 PM
Rick Irvine Rick Irvine is offline
I read that you have only 256 of ram.Digidesign specifically recommends 500meg for the 001.
It would surely be the most cost effective way to up your CPU power.
Old 11-11-2002, 07:29 PM
Unfortunately, that hasn't been the case on the DUC.
With 256 or better ram, it's more CPU power that makes a difference as far as plug in's go.
<font size="2" face="Verdana, Arial">
Old 03-24-2003, 06:11 AM
alhardy alhardy is offline
After asking digi support the same questions they answered that winXP and protools 5.3 (32Trk) consume more power than a 5.1 98/me system, therefore suggesting to upgrade to a faster cpu.
I upgraded to a amd 2400 with 1gig of ram and my machine is realy clean, but the error occurs, especially at 128 buffer size.
If U guys finbd a solution that'll be great.
Alberto Lombardi
Carbon - Pro Tools
Mac Mini M1
Ferrofish 16 I/O
www.albertolombardi.com
facebook - instagram - youtube
PLEASE HELP! PT 8 -- "running out of CPU power" at <15% of CPU usage jsbeeth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-01-2011 08:04 AM
"You are running out of CPU power" POPS, CLIKCS and HELL IN PT DCstudio10 Pro Tools M-Powered (Win) 24 07-12-2010 03:50 PM
what actually causes the "running out of cpu power" error... CamM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-30-2009 04:49 PM
error 9128 running out of CPU power with XP in10shun 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 07-12-2002 02:49 PM
running out of cpu power, error 9128?? Florian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-07-2002 11:15 AM
