Old 03-16-2024, 05:45 AM
babaorum babaorum is offline
Default PT 2024.3 windows 10 install impossible
I have a lot of error message as this (see attached), I tried everithing (register clean from pro tools , uninstall all avid , remove all avid folder etc ... but nothing works I have always these kind of message and when I'm looking for into the folder of the error the file is not present. Is my loading zip failed ... ? I retried it several times and always the same ...
Thanks for help
Pro Tools 2024.3 - Cubase pro 113 64bits- Windows 10 pro 64bits - wavelab 12 pro - core i9 9900K - 32 Go RAM All SSD- interface : ANTELOPE ORION Synergy Core.
Ideal-Sound Not_To_Flow
Old 03-16-2024, 08:23 AM
sw rec sw rec is offline
Default Re: PT 2024.3 windows 10 install impossible
Can’t say it’s “impossible,” since I’ve successfully installed it on three Win 10 machines.
Did you use Avid Link, (don’t!) or go to your account and download the installer yourself? (Do!)
Old 03-16-2024, 08:34 AM
jeam25's Avatar
jeam25 jeam25 is offline
I've seen a lot lately! Apart from SW advice if not using Avid link try another browser for download just in case.
Mac M1 Studio Ultra - Sonoma Beta OS
Avid Carbon Interface
Protools Ultimate
Old 03-16-2024, 02:18 PM
Yes I use my account and download ...
Old 03-16-2024, 02:19 PM
ok I'll try avid link and too another browser ...
Old 03-16-2024, 02:25 PM
You’re better off trying another browser but still downloading from your account. General consensus is avoid Avid Link. I downloaded all my Windows installers with Firefox and use the standard Windows app to unzip. On Mac I usually get the installer with Chrome.
Old 03-16-2024, 04:17 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
It worked fine for me installing with link on my backup system drive.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 03-16-2024, 05:31 PM
Forget Avid Link crap.
Lets try to troubleshoot by technically troubleshooting, not just guessing what is going on.
Go to the Avid Download Center (not My Products).
Download the 2024.3 Windows Version of Pro Tools.
Check the MD5 hash on that downloaded zip file with Certutil.
C:> certutil -hashfile Pro_Tools_2024.3.0_Win.zip MD5
You should get the expected a0dd92c1082d0028a8c02e331f9fd28e
(yes it should be the same if you download from My Products but I want you to see where the MD5 hash are documented).
If the MD5 hash do not match your problem is in the download/browser whatever.
If the MD5 hash matches then the problem has nothing to do with browsers/downloads, and the problem is in the installation: possibly what you are doing, maybe Pro Tools has a install problem on French Windows, or your Windows system is messed up.
If the MD5 hash matches then what *exactly* are you doing to the installer file after you download it. Describe every click or command you run.
Especially what exact tool are you using to uncompressed the installer zip.
Once the zip is uncompressed, and before running the installer, can you manually find the missing files that were reported missing before?
Search for those files in the old-school way... i.e. cd into the unzipped directory tree and then for the file mentioned in the screenshot...
C:> dir /s *Mono.dll
Do *not* try to find those files using Windows indexed search garbage.
Make sure your Desktop etc. is not using OneDrive garbage.
Disable Windows included and all other antivirus garbage.
Old 03-17-2024, 02:30 AM
That's what I do in fact.
Old 03-17-2024, 02:32 AM
Ho thanks for your advices, Do you have a link to the avid download center I'm not sure I'm on the good one (pro tools try version) ?
Streamdeck on Windows? Impossible? Cruz Azul Pro Tools 3 02-25-2024 01:50 AM
Pro Tools 10.3.2 wont even install! After clean windows 7 install!!! shamanrock Windows 13 12-27-2012 04:39 PM
impossible to install Viganio Windows 1 11-01-2012 12:29 PM
5.1.1 Install is Impossible pearlywhite 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-29-2006 11:52 PM
impossible to install 6.0.1 update mac osx! bdeivert 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-14-2003 03:38 PM
