Recording multiple takes with playlist mode
Hello,
I am still somewhat new to Pro Tools. When tracking and recording multiple takes, I have started recording on one track, and using playlists until either the best take is used or the comp is finished and the resulting track is moved to it's own audio track. My question is this: Every time the take is finished, I find myself having to grab the take from the top "waveform" area of the track and drop it down to the bottom thin sliver area of the playlists to move it into "storage" and create room for a new playlist. Is there any way for Pro Tools to do this automatically? Basically, I hope it doesn't sound lazy, but I would like to just be able to hit "3" to record the take, then when the take is finished, and just hit "3" again to begin recording right from the same insertion point and have PT automatically drop the take to a new playlist area. Does this make sense? Thanks in advance |
one more question!!!
Are the playlists when soloed playing at a lower volume than when they are copied into the main track? meaning when they are still just being previewed as takes inside the playlists are they at a lower volume then when you hit the up arrow button to copy them into the main playlist? Is there any way to adjust that? Thanks |
I can tell you are confused and its rubbing off on me. I suggest going to youtube and watching some videos on using playlists in pro tools.
This is how I do it: set my EDIT window track to show playlists(sometimes, if you don't select to show them, when you make new ones, the old ones, which are hidden, are made inactive due to some little PT bug). I name the track LdVox.01(or whatever the source will be, with the ".01" after the name). Now I record a pass on this track/playlist. Once its finished, I select Create New Playlist(it will automatically be named LdVox.02, which helps me keep track of which take is which). After that record pass, I create a new playlist(which gets auto-named LdVox.03, etc). Once I have all the passes I want, I create one more new playlist, and name it LdVox.COMP. Now I audition each pass in sections by hitting the SOLO button on playlist .01. Play a line>stop>solo next playlist and repeat Once I hear the best, I highlight that clip/area and hit the up arrow to place it on the "COMP" playlist. When I reach the end and have all my COMP audio on the top playlist, I set view to Waveform, which hides all the playlist record passes. As for volume, since all playlists play THRU the same plugins, the volume should never change(unless you cause it to change somehow, like maybe the singer doesn't stand at the same distance from the mic....
HP Z4 workstation, Mbox Studio https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix BTW, my name is Dave, but most people call me.........................Dave Last edited by albee1952; 05-19-2015 at 08:37 PM. |
control-command-\ duplicates to new playlist comp to the 'zero' playlist, or to a new 'comp' playlist - RTM about comping/playlist tools. No - same as main playlist
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
Editting Midi Takes in a Playlist View? | asounds | Pro Tools 9 | 2 | 09-12-2011 12:06 AM |
deleting takes from playlist | Maddawg383 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 26 | 10-18-2009 03:16 AM |
PT8 - Loop Recording w/Playlist Mode question | tha]-[acksaw | General Discussion | 1 | 05-07-2009 06:55 AM |
How to make Playlist Groups for different Takes? | funomatic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 03-23-2006 02:15 PM |
Recording multiple takes of the same song | Mike Glenn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 01-14-2002 07:35 AM |
