ProTools LE8: sending audio to s/pdif
Have Pro Tools LE 8 installed at home with Digidesign Rack 003 as the interface. Just been given a Focusrite VRM unit as another mix-down aid. This is driving me nuts trying to get it to work. Have installed the software from the CD; have connected the unit as shown with USB to computer and link to S/PDIF out on the 003 Rack using co-axial cable with RCA connector. VRM software shows S/PDIF locked so I am assuming the two units are recognising each other. What is defeating me - a Pro Tools new-ish user - is the simple statement "In your audio interface's control panel, ensure that audio is sent to the S/PDIF output of your audio interface". Can any more experienced users please explain - in simple terms - how I do this?
Many thanks for any help received. |
Re: ProTools LE8: sending audio to s/pdif
Pro Tools>Setup>I/O>Output Tab
Click 'New Path'>stereo> name it Focusrite VRM or anything you like. Click create. Now in grid, hover mouse over S/PDIF 17_18 and you'll see a pencil tool appear. Click in the boxes corresponding to the VRM path you created and a L & R will appear in the boxes. So looking at the grid as an X Y graph, if you follow the VRM path from left to right to channels 17_18 and then look straight up you will see that L & R that you inserted should correspond to S/PDIF. Now click on 'Default Output Bus' for a popup menu which will lead you to the VRM (or whatever you named it) path, then select that as default output bus. Click OK. It looks to me like the VRM has an internal clock source only which means it can't be synced externally. If that is indeed the case you will want to go to; Pro Tools>Setup>Hardware and set the 003R clock source to S/PDIF. Click OK.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Sending protools session online free? | broken81 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 07-13-2010 02:57 PM |
Sending protools projects to other protools users online | kdtufan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-24-2008 07:18 PM |
AMIII S/PDIF in from Second Audio Card S/PDIF Out? | bilco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-04-2005 10:30 AM |
Sending Audio via USB | powerjoe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 03-02-2005 09:23 PM |
Sending sessions to other ProTools user | haldude | Tips & Tricks | 1 | 10-14-2004 11:50 AM |
