ADC - Maybe a daft question
Hi
I have used PT LE since V7.1 and am really impressed by PT9, which I bought minutes after it was released. My question is...why would anyone NOT use ADC (it is something you have to turn on which suggests that there are situations where it would be left off)? Is it to do with processing power, plugs reporting false latency, simple sessions with no delay inducing plugs? Cheers Paul |
Re: ADC - Maybe a daft question
If I had to guess, I think that would be the biggest reason.
I think the first thing I'm gonna do, when and if I get PT9 is run a couple of tests to see if I can trust the ADC even a little bit. |
Plug-ins that report false latency can now be fixed within the ADC system by entering a user offset. Plug-ins that don't induce latency (at least in the RTAS world) wouldn't have any impact with ADC turned on -- same as if it's off. I can't think of a reason to ever turn ADC off in the RTAS world. ADC does have an impact on DSP usage in the TDM world. (I'm guessing that's why there's a "short" and "long" selection also.) So there might be a need to turn it off if you can't instantiate that last plug-in.
Kevin Windrem Sweet Spot Sound |
You would want to turn it off if you opened a previous session in which you had already compensated for plugin delay by sliding tracks around or using time adjuster.
The post I read says it does NOT compensate for time adjuster. That's the way it should be or time adjuster won't function as designed.
I'm wondering with the user offset if time adjuster might not be necessary any longer.
Mike.
This might qualify for "the best worded, but most idiotic thing I've ever heard said" award.-ejwells Avid Pro Tools|HD Native 9.0.3. Win7x64Sp1. i7-930 X58A-UD3R. Acronis backup. Black Viper optimized. Google the DUC Search Avid |
I gotta read up on user offset... |
Some interesting points. I hadn't really thought about the existing sessions where tracks may have been nudged ahead to manually compensate. I guess those tracks (as they have been moved physically) would then be compensated out of time.
So, in most normal circumstances (if they actually exist), you should have it on and rejoice that the world just got a bit better for us non-HD bods? Paul |
Daft punk robot voices | Raoul23 | Tips & Tricks | 9 | 06-27-2013 04:47 PM |
Synth design by daft punk for tron questions | DrFord | General Discussion | 1 | 12-31-2010 08:51 AM |
how do I get that daft punk vocal sound | DrFord | Pro Tools TDM Systems (Mac) | 17 | 01-15-2009 11:37 AM |
Anyone know Daft Punk's kit list? | tommydee | General Discussion | 0 | 11-09-2002 08:58 PM |
RTAS filter plug ins? daft punk/fatboy slim | Dopamine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 11-28-2000 10:58 AM |
