Old 11-27-2002, 11:37 PM
planet X planet X is offline
Default Tab function ???
You know that hitting the TAB key moves the cursor along to the next transient (invaluable for editing drums). Well all of a sudden it has stopped working?.
Trashed the prefs, fiddled with various setting and still not happening.
Anyone got any ideas.
Thanks
System
HD2
192
Dual Mac
Old 11-28-2002, 12:01 AM
ToolWeanie ToolWeanie is offline
Default Re: Tab function ???
Make sure that you have the "abc" button in the upper left hand corner on and then also make sure that you have the "TAB to the next transient" button on in that same upper left hand corner.
Old 11-28-2002, 06:37 AM
Thanks I will try that.
Old 11-28-2002, 03:14 PM
Scalp Scalp is offline
Or maybe you have a plug in open.
It's desactivate the tab function in the edit window and let you go from one parameter to the other in the plug in window.
Try to click in the plug outside a parameter, it's reactivate the tab function without closing the plug.
Old 11-29-2002, 03:33 AM
OK, I will try that also. The other suggestion hasnt worked either. Very strange. One day it works the next it doesnt?
Old 11-29-2002, 06:45 AM
RicardoEscallon RicardoEscallon is offline
Are you sure your TAB key is working properly? Someone came to me once telling he had encounter a bug with some comand that involved the ALT key. I tried the other ALT and it worked. So it was the keyboard.
Just check to make sure,
Ricardo
Alt key function, help. steviemac74 Pro Tools M-Powered (Win) 7 02-24-2009 01:51 AM
Using shift function John Edwards UK Pro Tools TDM Systems (Mac) 5 09-03-2008 08:23 PM
Tap function. the_dr38 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-25-2005 05:49 PM
Tab key function APinkFloydSound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-19-2004 08:06 PM
Request for function buttons on DIGI 002 to function stoogee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-05-2003 06:57 AM
