Old 08-30-2009, 04:07 PM
CamM CamM is offline
Default what actually causes the "running out of cpu power" error...
...is it actually anything to do with the CPU maxing out?
Old 08-30-2009, 04:13 PM
flommer flommer is offline
Default Re: what actually causes the "running out of cpu power" error...
2 gb is the initial "sweet spot" on a Mac Pro.. 1 GB was always considered to be restrictive.. More is better (to a point)
As far as the error, what does your CPU usage meter show?
You can also watch Activity Monitor from the OS.. Just turn on the Floating CPU window..
If you start with a sparse session and gradually add plugins you might be able to discern which are the CPU hogs..
I can definitely cause the CPU to overload by adding lots of instances of Eleven, and the CPU meter goes up fairly linearly until that happens..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 08-30-2009, 04:49 PM
righto
9.0.5 "Running out of CPU Power" Dimak415 macOS 9 11-02-2011 02:13 PM
PLEASE HELP! PT 8 -- "running out of CPU power" at <15% of CPU usage jsbeeth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-01-2011 08:04 AM
"You are running out of CPU power" POPS, CLIKCS and HELL IN PT DCstudio10 Pro Tools M-Powered (Win) 24 07-12-2010 03:50 PM
Help! Error 9128 "Your'e running out of CPU power. Take out some plugins to free..." LATablette 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 03-26-2003 06:48 PM
do i have to buy "european" version of digi002, or use "american" with power adaptor? stoka General Discussion 3 10-04-2002 05:28 AM
