Old 04-17-2009, 07:05 AM
manyrains manyrains is offline
Default Sound output assign?
OK , stupid question, but... I'm running T Racks 3 as standalone, want to listen through my monitors instead of computer speakers. I select Digidesign HW in sound menu but it won't "assign". (like there should be an "apply change" button or something) What am I not doing right?
Also, if anyone can enlighten me, I seem to recalll that when I have successfully done this in the past, I had a little issue (can't recall the details), something to do with not being able to locate my Digi HW after I reverted back to outputting computer sound out the speakers. Something to do with Core Audio Driver? Can anyone explain to me what goes on there?
Thanks
www.jimsavage.net
www.manyrainsmedia.com
Mac Pro Late 2013, 3.7, 12GB, Apollo Twin, PT12, ADL 600, UA 2-1176, Mojave MA-200
Old 04-18-2009, 08:31 PM
Default Re: Sound output assign?
Anybody?
www.jimsavage.net
Old 04-19-2009, 02:33 AM
BradLyons BradLyons is offline
Hey Jim, how's it going? The CORE AUDIO driver certainly could be better implemented, but you're confusing it by switching it back and forth. Just pull up the plugin within ProToolsLE instead of stand-alone----you're a lot better off doing it that way for quite a few reasons......just working, having access to other plugins, playlists, pre-sets, etc.
Thank you,
Brad Lyons
www.howavl.com
Old 04-19-2009, 08:49 AM
My reason for wanting to use it standalone is I can hardly use it at all in PT as it creates CPU chaos. Someone said my dual 2.66 is the problem- I'm sort of stunned to hear that. I'm still trying to find out if there's something I'm not doing to reduce the CPU stress. But I've never had a sniff of CPU issues prior to this.
Anyway, I know I've run Itunes through PT before to listen in my monitors. For some reason I'm not getting it to go this time.
www.jimsavage.net
Old 04-19-2009, 09:07 AM
I installed PT 8 on a new HD and upgraded from 10.4 to Leopard. I still have Itunes on the 10.4 drive, that works assigning sound to 002r. I just noticed on my Leopard/PT drive, the sound output box says "device has no output controls". How do I set output controls for 002r in this situation?
www.jimsavage.net
C|24 - can I use the control surface to assign output bus? A Chapman ICON & C|24 8 01-03-2011 04:12 PM
ProjectMix I/O Output assign question Kafrifelle Pro Tools M-Powered (Mac) 3 08-09-2010 09:59 AM
Can't assign output, not enough DSP? crizdee Pro Tools TDM Systems (Mac) 2 04-04-2008 12:05 PM
Bug in Sample Output Assign quantise Virtual Instruments 1 03-22-2007 06:51 AM
assign audiosuite preview to output? StainedClass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-12-2003 10:52 PM
