Old 02-26-2008, 05:35 AM
nuone700 nuone700 is offline
Default can\'t record on audio track 2
I'm a pro tools newbie--have a mac pro running 10.4.11 with 5 gigs ram and a separate 400 gig drive for audio and am using pro tools le 7.4 and a new mbox2 pro.
I need to record voiceovers for an animated short and would like to assign a different voice to a different track (just makes it easier to bounce to disk and save and shoot into After Effects.) In other words, for each session, I'd like to have, say, 3 separate audio tracks with different voiceovers recorded on them.
I can set up track 1 and record and save. But when I create a new track, it won't record on track 2--only track 1. I can't get a level on the second (or 3rd) track. Only on the first one. What am I doing wrong? Is there something I need to activate in one of the menues or preferences or is it an I/O issue?
Any suggestions? (and sorry if this is a really basic question...)
Thanks a bunch!
Old 02-26-2008, 06:25 AM
Phil Ogden Phil Ogden is offline
Default Re: can\'t record on audio track 2
When new tracks are created in Pro Tools, it usually defaults to the next available input e.g 1st mono track - input 1, 2nd mono track - input 2.
Make sure that the track input on the 2nd and subsequent tracks matches that which has the Mic connected (presumably input 1). Click the track input and a drop down menu will give you the various options.
http://www.myspace.com/philogg
Old 02-26-2008, 08:32 AM
thanks! that did the trick. I think I have to go over that dvd that came with the program (and the manual) to really nail the whole i/o thing and set it up totally properly.
thanks again.
Unable to Record (digitize) a Regular Midi Track to an Audio Track JuicyMusic macOS 9 02-27-2013 08:52 AM
Record 1 audio track, then go to record a second, the timer button flashes... help tdubthatsme General Discussion 5 02-27-2011 04:39 PM
PT 9 won't record audio track SoloMonk Pro Tools 9 9 12-13-2010 10:04 AM
Can Not Record On Audio Track 2... Please Help Wize Dome 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-24-2007 06:13 AM
How do I record a MIDI track onto an audio track? shemcom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-11-2003 06:13 AM
