Old 05-30-2006, 09:49 PM
MX MX is offline
Default mastering plugs other than waves
I am sure this has been covered...but what are popular mastering plugs other than the waves L2/L3?
Like the L3, but am looking for a non-wup replacement for further down the road.
thanks for any suggestions
Mark
Old 05-30-2006, 10:15 PM
filmixer filmixer is offline
Default Re: mastering plugs other than waves
To replace the L2, you might want try the Sony Oxford Limiter. Higher up the price scale, you should check out the TC MD3 as a alternative to the L3. If you don't necessarily need a TDM plugin, the Izotope Ozone is a good one to try.
Mark Ettel C.A.S.
Old 05-31-2006, 04:44 AM
TCDet TCDet is offline
Izotope Ozone
In PT's 7.1cs7 and in Waveburner it's been a very clean plug-in.
At first it's easy to get carried away but once your aware of it's power and keep to subtle changes...well it's quite good.
Note:
1. it was a dog on a G4 dual 1, but a G5 dual 2.7 it's as it should be.
2. Not yet optimized for 7 but indications are that this will be coming.
(Still it works fine as a RTAS on the Master)
Try the demo! Ozone 3
Old 05-31-2006, 09:19 AM
rinky rinky is offline
Just used Ozone to master a CD project for the first time. Have been using the Waves plugs but decided to try Ozone out since many have been pleased with its results. I was pleasantly surprised how clean it sounded. I A/B'd it to my previous mastered projects using the L3 but for this price and sonic quality, I was very happy. Used in moderation, one can produce a masterpiece with this intuitive and nicely priced alternative. Yes, give it a try for free and post back.
PT Ultimate 2024.3
PT HDX
MacPro 7,1 (Intel)
16 Core
96 GB ram
macOS Ventura 13.4
Somehow, musicians are now technicians!
Old 05-31-2006, 12:11 PM
25ghosts 25ghosts is offline
DAWG - u Gotta get this one
MD3 from TC ELECTRONIC - just tried it and it beats the living SHYT out a the rest out there)))
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10
Old 06-05-2006, 08:19 AM
Studio Dweller Studio Dweller is offline
Haven't tried the TC plug, but I've been extremely pleased with the Oxford Limiter and haven't used the L2/L3 since I got it.
Larry
Cellar Dweller Productions
PT 2020.3.0 HDX, HD IO 16x16 analog, 192 I/O, Control|24
Mac Pro 2019 16-core, 96GB RAM, OS 10.15.2
Old 06-05-2006, 10:31 AM
Detlef Brockmann Detlef Brockmann is offline
Hello,
I've just downloaded this one:
http://www.masseyplugins.com/L2007.html
and played around with it. Sounded very clean compared to the L1.
Detlef.
Old 06-05-2006, 11:42 AM
frenchman frenchman is offline
The real question is what you expect from the "mastering" process
If you need something quite loud, big, sweet and in your face (95 % of pop today), then it will depend *a lot* on the source mix.
1 - If the mix (notice the number of ifs...;-) ) is good for that purpose, ie if the dynamics of each ingredient in the mix are 100% under control and the frequencies (notably bass freqs ) in each track have been dealt with correctly, then a little eq (if needed) + maybe a good compressor to cheat a little on the transients, and to finish a brickwall limiter (L2, Sony limiter) should be enough
2- if on the other hand the mix is, well, a little sketchy and need serious pumping up to be able to stand comparison to well known stuff on an average A&R man bad sound system, or sound like FM radio, then you need heavy multiband artillery stuff like L3, TC etc.
Mark Haliday
France, Rochefort 17300
Mixing & Mastering, Writer, Teacher
Pro Tools Ultimate & Carbon
M2 Max Studio
Old 06-05-2006, 01:53 PM
Sonny Keyes Sonny Keyes is offline
Hello,
Detlef.
Awesome! ...and cheap!
I just tried it too, and I thought it sounded so much like L2 that I tried mastering the same song twice, once with L2 and once with Massey's L2007 with the same settings. Imported them into a new file, flipped the phase on one and got...almost silence!
I know that doesn't necessarily prove much, but given the disparity in price, it's definitely worth noting.
Sonny Keyes
Ricochet Audio
Toronto
Sonny Keyes
Toronto
http://www.sonnykeyes.ca
Rig 1: 2.8GHz Macbook Pro PT 12.7.1 Logic 10.3.2 Scarlett 18i20
Rig 2: 2.66 QuadCore Intel Xeon Logic 10.2.0 Scarlett 18i20 PTHD10.3.10
Mastering in ProTools with Waves Masters Plugs Torchlight Tips & Tricks 3 02-25-2007 09:26 PM
Plugs Advice: Sony vs Waves - Sonalksis vs Waves? John J. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-08-2005 01:31 PM
Logic mastering plugs vs. Waves? THETHRILLFACTOR Pro Tools TDM Systems (Mac) 2 03-14-2003 08:38 PM
Mastering singles for radio with new Waves Mastering suite. Peter Duemmler Pro Tools TDM Systems (Mac) 14 06-21-2002 05:14 PM
Mastering singles for radio with new Waves Mastering suite. Dimension Zero Tips & Tricks 0 06-15-2002 12:32 AM
