Old 08-31-2009, 11:26 AM
gvees gvees is offline
Default Re: do you have probs w/ digi tech suprt utility?? i got a fix!
Hey Steve,
It works great! Only after running it it asks to put a disk in my A: drive (3,5" diskette drive). Nothing bad really, i just click cancel, but thought you might wanted to know...
Thanks for the nice little app!!
Old 08-31-2009, 01:25 PM
Originally Posted by gvees View Post
Hey Steve,
that is odd! never seen that before. maybe when i get time i will have to do some experimenting with it. glad you like it. i have some other shortcut packs i will get out soon hopefully.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 08-31-2009, 02:42 PM
Cool..! Looking forward to it...
I hope this resolves that I don't have to reboot Win7 several times before PT boots completely (sometimes it takes three/four times to reboot to get Pro Tools to get past the 'DAE Objects' message).
Old 08-31-2009, 02:48 PM
oh your using win 7???? i have not tested trasher with it. i know mykhal is running it so maybe i will give him a call and have him check it their. i am in the midst of getting a removable drive bay so i can swap my c drives so i can start using win 7. want to keep it seperate from my xp partitions. will get this checked out. thanks for the heads up! and any thing else you find let me know
pro-tools-pc.com
Intel I7 9900k
Win 10
Old 09-03-2009, 11:12 PM
mercurysoto mercurysoto is offline
Thanx a lot. It worked alright. Countless kudos!
Take the red pill and I'll show you how deep the rabbit hole goes.
Old 09-04-2009, 12:01 AM
thank you and glad it worked!!
if anyone has ideas for changes or updates, or just kind words feel free to post.
pro-tools-pc.com
Intel I7 9900k
Win 10
Old 09-04-2009, 06:57 AM
scottedog scottedog is offline
Unfreakinbelievablyamazing!
Scott.
ScottedogStudios on ReverbNation
Old 09-04-2009, 07:18 AM
that my friend is one cool word!! unfrekingbelievably.......it has a ring to it will have to try to get it into a sentence today somewhere!!
pro-tools-pc.com
Intel I7 9900k
Win 10
Old 09-04-2009, 06:33 PM
scar97 scar97 is offline
Can you verify this work on XP 32 bit sp3? I only saw win 7 32
"It aint about the stuff you got..If it sounds right you're finished..Burn it!"
For all complaints click here
DAW
Digi003 PC-Sweetwater CS dual 3.0/Asus 975X Chipset/CPU dual 3.0GHz/800MHz FSB/RAM 4GB/Radeonx300se/4 internal glyph sata drives/ 3 external glyph backup drives/Acronis True Image OUTBOARD-UA LA-610, ADL-600, Digimax lt, Eureka x 2, Central Station, Hearback x 8, JBL LSR, Monster Power Software-PTLE 8.0, Sound Forge, CD Architect Plugins- Too many and too much money spent
Old 09-04-2009, 06:36 PM
The reason I am asking is the file says 32 bit OS. OS means mac to me
Just want to make sure. I am installing 8.0.1 tonight and want to update evrything including that old POS from digi. I find it strange that you guys can program what is right and digi can;t. What is up with that?
DAW
Tech Support Utility Fail audiogeekzine Pro Tools M-Powered (Win) 2 08-23-2010 07:20 PM
Digi Tech utility launch message Kirby B. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-20-2009 02:12 AM
Tech support utility in PT8 scar97 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 12-26-2008 08:42 PM
DIGI...Tech Support Utility error mykhal c 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 01-22-2008 07:36 PM
Tech support utility tamasdragon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-04-2007 12:00 AM
