VST to RTAS adaptor problem?
hi...my VSTs using FXpansion show up under my instruments in protools 6.9 ..no problem so far..but then i can't get any sound out of them...should i take an extra measure with wrapped instruments to hear the sound?..with rewire option that it comes with some VSTs i never had this problem....please help.......thanks a lot
Re: VST to RTAS adaptor problem?
No, you shouldn't have to take any extra steps; they should work like any other RTAS instrument plugin.
Make sure the volume on the aux track is turned up. Make sure that you have a patch selected. Make sure you have the output of the MIDI track set for the instrument you are trying to access.
I've been using the adapter for about a week now. The only problem i've had so far is with the kjaerhus classic series vst effects. The GUI for these plugs doesn't adapt properly - the knobs for the effects don't show up. I have to click a few times where each knob should be and they start appearing but i still can't see the numeric values. They still sound right though.
http://hifiat32.com |
thanks for response...yeah, i made sure every thing was where it suppose to be..in fact with the same setting i can load other instruments such as BFD or anything else and every thing works flawlessly...Even programs like atmosphere which has a rewire option built in it , works fine, but when i try to use the wrapped version of atmosphere i can't hear the patches any more....so i assume something is wrong with one setting somewhere that doesn't let me hear wrapped instruments...any thoughts?
I've had problems with Free Amp SE. The plug loads,wraps, and works properly - however, if I try to close the session or remove the plug-in, my ProTools sessions crashes so hard that it tells me I need to reboot.
____________________________________ Home Build: Core i7 920/Gigabyte EX58-UD3R/6Mb Ram Mbox2/MboxMicro ProTools 8.0 |
Which version of the wrapper?
What plugins specifically are you having problems with? Is it only Atmosphere? Or every VSTi? (P.S. as far as I am aware, Atmosphere does not have rewire capabilities. RTAS? yes. Rewire? Not that I know of.)
yeah, may be you're right about Atmossphere ..i have to go and check on that...but i know for sure that i have a couple of steinberg plug ins that are older version and don't support rewire or RTAS...so when i use FXpansion vst to rtas adaptor, they show up under instruments and i can open them up (such as virtual guitarist from steinberg) ,but i don't get any sound..and when i use exactly the same setting with other instruments/plug ins i have no problem....i'm also not sure what version of Fxpansioin adaptor i have..when i go home later tonight, i'll check it.....
OK I CHECKED IT ..I HAVE FXPANSION VST TO RTAS ADAPTOR VERSION 2.0...DOES THAT HELP AT ALL?....THANKS
Yes, it helps. Version 2 is for Pro Tools 7 and above, and won't work with older versions. Version 1.06 should be available for download for you from fxpansion, and is the one you need to work properly with Pro Tools 6.9, Just log in over at FXpansion and check your update page for the download info.
which vst - rtas adaptor/converter? | TheNoodlemeister | Virtual Instruments | 41 | 07-05-2016 03:56 AM |
FXPANSION: VST TO RTAS ADAPTOR PROBLEM | tritonkorg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 05-26-2006 10:26 AM |
vst/rtas adaptor update will be 49usd when.... | eyeknow | General Discussion | 9 | 11-19-2005 05:03 PM |
VST to RTAS Adaptor vs. ReWire to RTAS Adaptor | TriAxis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-22-2004 10:28 PM |
ProTools LE - UAD1 with VST to RTAS adaptor?!?! | FunkNotPunk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-13-2004 02:13 AM |
