Old 10-16-2005, 07:23 PM
kontrol kontrol is offline
Default a good way to get rid of popping noise (clipping)
Im new to protools, just got it yesterday, however I am some what experienced with recording. My quesiton is, after recording an audio track and u want you're recording to fit into a sertain amount of bars....what is the best technique so that you dont need to use fades to hide the clipping noises after trimming?
P.S. I understand that you need to trim the wave in the audio when it crosses 0...but is there better/faster way of doing this? thanks to anyone who can help.
Old 10-16-2005, 08:12 PM
BxThree1 BxThree1 is offline
Default Re: a good way to get rid of popping noise (clipping)
use a compressor you can use the one that comes with protools.
Hip Hop B.D.B.C
Boogie Down By Committee
© 2004 Stylez, INC
Old 10-16-2005, 08:58 PM
You are joking, aren't you?
Quad 2.5 G5, 4.5G RAM
Old 10-17-2005, 05:28 AM
RadioMoo RadioMoo is offline
Why don't you want to use fades? The crossfades in PTLE (Command+F) do a good job of masking those pops and blending edited stuff together - if you don't select too large of an area.
You could try making your cuts a little too long, then using the Trimmer tool (F6) to trim them to the point that you want to use, which would also trim out the pop.
Mbox 1 w/BLA mod, PTLE 6.1, eMac 700MHz, OS X (10.2.8), 1024 MB RAM
Clicking and Popping Noise Funkle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 28 09-05-2010 02:17 PM
How much clipping is good clipping ? jaunmanuek The Drum Room 9 04-12-2010 05:49 PM
Popping noise Stickman7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-26-2009 05:59 PM
good way to get rid of popping noise (clipping) kontrol Tips & Tricks 7 07-22-2008 07:01 PM
help with 002, popping noise DLinares 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 01-16-2006 11:09 AM
