Scrubbing Audio with the keyboard?
Similar to what the scrubber tool does but using the keyboard on a frame by frame basis?
Is this possible? Like what you can do in video editors, but I want to do this in PT as that's what the finished product will be in. Cheers to anyone who can help :) |
Re: Scrubbing Audio with the keyboard?
I'm not sure if you're describing nudging or scrubbing.
At any rate, you can set your nudge value to 1 frame, and use the + and - keys to move the playhead forward and backward by one frame. You can also change your numpad mode to "Shuttle" (setup->preferences->operation->transport). Have a look at the manual for how they controls are laid out, it's pretty easy once you get used to it. |
No it's definitely scrubbing. It's like what the scrubber tool does, you know when you drag through with the mouse and hear the audio. Not nudging, the regions, or clips as they are nowadays are staying exactly where they are.
I want to do that but using the keyboard. So I can hear audio every frame of my film. Does that make sense? Basically, if you go to anything like final cut, media composer or premiere, you can go through each frame and hear the audio for it. I'm recreating the sound track to a short animation and using the original sound track as a reference, noting every sound that occurs and at what timecode. I just want to do everything in PT rather than have to use a video editor. |
Best way I can think of, is to set grid and nudge values to 1 frame, make a selection of 1 frame, and then you can nudge this selection back and forth with +/- on the numpad, and of course initiate playback with spacebar.
Probably the closest way I've seen. Still means a constant "hit nudge, press space, hit nudge, press space" etc. The video editors just allow you you hit nudge and it will play that frame and allows you to rock backwards and forward to find specific transient. Useful for pinpointing sounds you cant easily see on a waveform, but can hear quite clearly. I was under the impression shuttle mode just changed the playback speed. I am not playing back larger portions of audio. I just want to hit nudge, hear that frame of audio, hit nudge again, hear the next frame of audio, hit reverse nudge, hear previous frame etc. |
Thats what scrubbing is.
its not really scrubbing is it, you are limited to the speed selections and its more difficult to use than scrubbing.
Plus i didnt say I wanted to scrub, I said it's similar to scrubbing, I dont actually want to scrub. I want to hear a frame of audio at a time using say the left and right arrows or plus and minus or whatever. |
At any rate, If you prefer to use nudging, go for it. I listed that in my first comment, anyway... |
I think just making a small selection and using the [ key to play selection is the closest. If you are real fast. You can use the down arrow to mark your start, press play and immediately press the up arrow. Then press [.
Note that [ and ] play the time line OR selection if edit and timeline aren't linked. Some mice come with pretty fancy control panels that can transfer some mouse functions to mouse keys. I think the artist control does this stuff but I might be wrong.
Dave Cournoyer-guitarist-project studio Mac Mini late 2012, i7, Sierra 16GB PT10.3.10HD PT12.5.2 Apogee Mini-Me firewire. |
Key scrubbing with audio? | dino_squirrel | Pro Tools 10 | 2 | 08-19-2012 01:18 PM |
How do I record the audio "scrubbing"? | eddster08 | Tips & Tricks | 8 | 09-30-2007 12:13 PM |
scrubbing audio through a mix bus | Rea Engineering | Pro Tools TDM Systems (Mac) | 6 | 12-10-2005 12:27 PM |
canopus and scrubbing audio | D Evans | Post - Surround - Video | 1 | 10-02-2003 05:48 AM |
Audio Scrubbing??? | roijin | Tips & Tricks | 7 | 08-24-2001 09:13 AM |
