Old 04-15-2015, 01:26 AM
actual actual is offline
Default Mac Mini 2014
Hello,
I have a Mac Mini 2014 and want to run Pro Tools 10 or 11. The Avid site doesn't list this hardware as supported but I was hoping someone else here could advise me?
Thanks in advance for any advice you can offer,
Mac Mini 2014
Processor: 2.6GHz
2.6GHz dual-core Intel Core i5 (Turbo Boost up to 3.1GHz) with 3MB on-chip shared L3 cache
1TB (5400-rpm) hard drive
8GB of 1600MHz LPDDR3 memory
Two Thunderbolt 2 ports (up to 20 Gbps)
Four USB 3 ports (up to 5 Gbps)
HDMI port
SDXC card slot
Gigabit Ethernet port
Audio in port
Headphone port
IR receiver
Old 04-15-2015, 01:55 AM
Bookerv12 Bookerv12 is offline
Default Re: Mac Mini 2014
This info is everywhere.
The latest mini was hobbled with an i5 processor compared with the previous i7 model. (Apparently it was too close to a Mac Pro)
You can probably use it, but will need a fast external audio drive.
I have a friend who just set up an HD Native system on a new mini and ended up getting a faster computer after a lot of frustration.
You could probably run smaller sessions on it, but start adding instrument tracks and you will be in trouble.
Sorry, but this is what I have seen in real life.
bookerv12
Old 04-16-2015, 07:16 AM
noah330 noah330 is offline
I'm actually about to look for a new computer to run my HD Native system on and found this thread.
Right now I'm running an older Mac Pro with PTHD 9.
The two options I'm looking at are Hackintosh or a Mac Mini. I would love to buy a MacPro and if it had a PCIe slot I may have considered it.
I was looking at the 2.6 i5 that is $699. Anyone have any experience with this?
Old 04-16-2015, 12:35 PM
DetroitT's Avatar
DetroitT DetroitT is online now
"...a MacPro and if it had a PCIe slot I may have considered it."
Well, no PCIe on the mini either. and limited to 16 GB memory (Good for some).
However if you go the mini then get the i7 Maxed with Flash boot and memory.
Or consider pumpin' up a 2010-12 silver tower with SSD's, Video GPU and Memory.
(Help us Help You)<<<click here
Testing:All APFS 90% 10% Audio on HFS+(Testing 1.5 yr in)
Pro Tools U-2019.6 MacOS 10.14.6
Second boot-10.13.6 (Avid HDX-1 Omni)
(MP 5,1 / 64-Gb)
(Sapphire RX-580 MacVCEdition, 3-Displays)
MOTU FW-CoreAudio (for poly recording)
(SSL-HUI-MIDI over IP)
music-design-creation
Post Music-Sound mixing, Production-Enhancements.
Audio Tuning and System Services
Help me decide on a used 2014 Mini Mac lydpik macOS 5 12-15-2014 01:34 PM
New Mac Mini Oct 2014 Obsidian Dragon macOS 45 10-23-2014 09:19 PM
Mac Mini 2014 Marcel Risberg General Discussion 24 10-19-2014 05:42 PM
2014 New Mac Mini's coming YYR123 General Discussion 4 10-08-2014 02:49 PM
Mbox 2 Pro Not Compatible with 2014 Mac Mini kitorod 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-07-2014 04:07 PM
