Old 04-15-2009, 04:09 PM
bcs723 bcs723 is offline
Default Jumping Faders???
Tonight I was in a service and in the middle of a teaching with no hands on the console, the 2 mics that were in use, the faders went to +12, then all the way off, then back to original position. No audio was effected...
Anybody ever experienced this?
Old 04-15-2009, 05:57 PM
Roland Clarke Roland Clarke is offline
Default Re: Jumping Faders???
That's what happens when the console is first initializes, sounds like you possibly had some sort of power interupt to the surface.
Regards
Roland
Old 04-15-2009, 06:17 PM
I am running on a UPS. Also, those 2 faders were the only ones effected. All other faders were all the way off and didn't move at all.
Old 04-26-2009, 08:13 PM
rfindley rfindley is offline
I've seen another odd Venue fader problem once...
On the output faders section (aux/groups/vca/etc..), I normally have the VCA's selected for these faders. I switched briefly to the Aux bank, then back to VCAs. When I switched back to VCAs, one of the faders stayed at its Aux position instead of moving back to its VCA position, and the sound levels connected to that VCA all dropped (to where the fader stayed). It look only a second to correct, but a lot of heads turned back to the sound board.
Anyway, something for the Digi guys to keep in mind.
Old 05-06-2009, 12:01 PM
JW3 JW3 is offline
If you shut down the software then run fader tests on the console to recalibrate the faders, that will fix your problem. I run the fader test once a month just to get dust and stuff out of there.
Control 24 faders jumping/not working fix!! crizdee ICON & C|24 1 09-30-2013 04:44 PM
Custom Faders moves position of all other faders!?! freeBase ICON & C|24 5 02-26-2009 06:44 PM
003 faders sticking/jumping back to 0 steve mezclador 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 09-15-2008 11:27 AM
control 24 faders jumping around crizdee Pro Tools TDM Systems (Mac) 7 09-22-2005 01:55 AM
USING MIDI FADERS TO CONTROL PRO TOOLS FADERS.... domsound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-08-2004 07:06 PM
