Old 03-03-2018, 08:24 AM
DonaldM's Avatar
DonaldM DonaldM is offline
Default Re: Best DNxHR Preset for working with video in Pro Tools
Originally Posted by tom_lowe View Post
At 1920x1080 DNxHD 36 is your best bet.
That’s what I thought. Thanks.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Old 03-05-2018, 05:31 PM
AndrewAction's Avatar
AndrewAction AndrewAction is offline
DNxHD 36 is good but it has a draw back in that is a "Progressive" only format that does not handle interlace video.
All of the DnxHR range handle either Progressive and Interlace formats. As pointed out earlier in the thread HR formats can be any resolution. So you can use one codec for your media needs from the ancient Standard def 720 right through to 4K.
The HR file sizes are not that enormous. Yesterday a 10 minute standard def clip clip produced a 2GB file in DNxHR HQ. A LB version was a quarter of that size which is roughly equivalent to DV file sizes. I used HQ as I could then supply the same video file to both Colourist and Audio Post.
FWIW my not particularly powerful PC here running W10 and PT 2018.1 HD had no trouble playing this DNxHR HQ file. Admittedly this is only a simple 16 track session at present.
Andrew
Old 03-06-2018, 01:25 AM
tom_lowe tom_lowe is offline
Andrew
But for ref playback it doesn't matter if it's progressive only. Most workflows send a different video to audio as to the colourist. DNxHR only officially supports HD resolutions as proxies in 4K projects. For HD Avid still recommended DNxHD and in projects which are HD only resolutions you can't choose DNxHR as your editing CODEC.
HQ is overkill for audio post especially if running large sessions, I frequently run over 100 tracks even for very short things, hence DNxHD 36. If an editor sent me the same file as the colourist I'd transcode to something smaller.
http://avid.force.com/pkb/articles/e...Specifications
* HD resolutions are only available as a proxy setting in a High-Resolution project. There is no way to select DNxHR resolutions from within a HD project-type.
Old 03-06-2018, 02:36 PM
Everyone develops their own workflows that work for them. I am saying that the DNxHR is a viable option for folk with a variety of workflows
But when asking an MC editor for DNxHD36 they cannot easily export to this format from an interlace project DNx HD 85 is smallest easily available to them.
Yes but the MC editor sending different formats is probable the same so in life here I can send DNxHR LO to audio Post then DNxHR HQ (12bit) or DNxHR 444 to the colourist.
As an MC editor my MC edit format is irrelevant to the Output (export) format I need to deliver to Audio post.
I only used HQ as an example of one I had just done. It went to a Colourist. FYI I Output from MC this morning a 1 minute file to DNxHD 36 and then to DNxHR LO. File sizes DNxHD 36 was 317 MB's. DNxHR LO was 315 MB's.
*HD resolutions are only available as a proxy setting in a High-Resolution project. There is no way to select DNxHR resolutions from within a HD project-type*
For the video editor neither of these restrictions are relevant. What maters is that the MC editor can export DNxHR LO files to Audio Post from any MC timeline resolution.(SD through to 4K.)
IMO the answers above all used here show that DNxHR LO would be a reasonable option for some Audio post situations.
Andrew
Old 03-06-2018, 04:30 PM
Watagushu2013 Watagushu2013 is offline
The códecs that we use are changing all the time and there are good things that matters from the workflow perspective.
I think that if this new one is better for all the folks involved in the post process, let’s work for the team and use the best option within any project.
  #16
Old 03-07-2018, 05:15 PM
Yes but the MC editor sending different formats is probable the same so in life here I can send DNxHR LO to audio Post then DNxHR HQ (12bit) or DNxHR 444 to the colourist. As an MC editor my MC edit format is irrelevant to the Output (export) format I need to deliver to Audio post. I only used HQ as an example of one I had just done. It went to a Colourist. FYI I Output from MC this morning a 1 minute file to DNxHD 36 and then to DNxHR LO. File sizes DNxHD 36 was 317 MB's. DNxHR LO was 315 MB's.
Andrew
By LO do you mean LB? I'm fully aware editing and delivery CODECs can be different, but everything I've read says DNxHR is for resolutions above 1080p, not 1080p and below as well.
Are you saying it's resolution independent like ProRes?
  #17
Old 03-07-2018, 06:22 PM
Yes.
For Outputting (new name for Export in MC) yes. I can and have Exported from MC projects from Standard Def through to UHD format to DNxHR LB codec where I set my desired resolution to any standard video format. (I have exported to these SD, HD, 2K, UHD).
I have not looked at the possibilities for non standard video resolutions but in your choice of codec is a Custom option that may do this. (It works for non standard sizes with other codecs like MP4)
Attached file shows export option of DNxHR LB
Last edited by AndrewAction; 03-07-2018 at 06:23 PM. Reason: Added note for attachment
  #18
Old 03-09-2018, 04:21 AM
Yes.
Good to know. I'm not an MC user and my current clients aren't either, but good to know this is a future option
  #19
Old 03-10-2018, 03:50 PM
Marco Bernardo's Avatar
Marco Bernardo Marco Bernardo is offline
I've made this little "app" converter for mac users. It uses ffmpeg, converting any file to apple pro res proxy. For now the app can't work with path and files that have SPACES between letters.
Create a folder at the root of you volume with the name Convert and rename the file if have spaces.
Download here
Hope it helps.
Marco Bernardo
Dialog Editor, Sound Designer, Re-Recording mixer
nMacPro 6Core/D500/512GB/64Gb ram | PT HD 12 HDN Thunderbolt | HD OMNI | Avid Artist Mix | Novation Impulse 25 | Waves Mercury Native | Audioease All In Bundle | SoundToys | McDSP Classic Pack | DUY Overpack | Arturia Beatstep Pro
HTML code is On
Pro Tools First Quandary About Working With Video Austin4 Pro Tools 12 4 07-12-2017 11:04 AM
Video not working in Pro Tools 11 mortenbrekke Pro Tools 11 25 02-15-2017 10:22 PM
DNxHR Marcel Risberg Post - Surround - Video 8 04-21-2016 11:17 AM
Syncing audio/video & Working with Premiere Pro and Pro Tools millsi Post - Surround - Video 6 02-07-2011 01:00 PM
Preset Menu Not Working! lukec 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-08-2007 08:17 AM
