midi controllers dont work in PT 12
I was running 9 for a long time. It was stable, everything worked. yesterday I made the mistake of switching to pro Tools 12..what a nightmare. 2 days of work..installing, uninstalling, updating, patching, newest versions of everything I own, and forum after forum. The level of aggravation and frustration is beyond words. Why did I switch? I should have left it alone, my recordings were fine on 9.
So now my padKONTROL and M-audio axiom keyboard do not work at all. They light up, that's it. I downloaded newest drivers available, looked for new firmware (none found) I uninstalled it, reinstalled it several times. I restarted pro tools, and my computer an infinite amount of times. The padKONTROL doesnt even show up on the list of peripherals. I check my wires/tried different ones. I power cycled it like a million times. My mackie control universal and extenders are fine. Midi thru is checked. my USB hub is functioning correctly. I am at wits end, I just want to use this very expensive software and just make some music...I know that's a lot to ask. here's the equipment rundown: dell xps 8500 with I7 processor, and 16 gigs of ram. windows 7 (64 bit) Glyph GPT50 hard drive Mackie control universal, and two extenders Tannoy monitors Dual Dell monitors (24 inch flat screens) Dual furman power conditioners 8 channel headphone amp M-audio fast track ultra 8r Lindell pre amps x2 Lindell eq's x2 Lindell compressors x2 Eleven rack Korg PadKOntrol M audio axiom keyboard AKG monitoring headphones Vic Firth tracking headphones Mics: royer 121, senhieser 421, ev re-20, sure beta 57 x5, sure beta 52, sure KSM 137 x2, Sure 58, MXL v69 tube. and a Ton of other stuff I cant remember right now. So how do I get the korg padKontroll to be reconised in pro tools 12? What's the secret? Do I need to dump it and just buy some other special pro Tools compatible and ridiculously expensive controller? Do I need to go to a witch doctor? Maybe hire an M.I.T technician? This is the last stpe left before being able to record (I think). ANY suggestion would be welcomed. |
MIDI Controllers not working in PT 12
I cant get half my midi controllers to work in PT 12.
Re: MIDI Controllers not working in PT 12
yeah I've been struggling with the same problem... did you find a solution?
Re: midi controllers dont work in PT 12
Yes , none of the Native Instruments controllers work either.
Try plugging the controller into your computer BEFORE launching Pro Tools.
I use a Korg nanoKey2 and it won't register if plugged in while Pro Tools is running. Plugging the controller in before starting PT works for my W7 system. Last edited by take77; 02-05-2016 at 03:31 PM. |
I've found that having the controller powered up and running BEFORE launching PT is required at least in a Windows 7 environment.
Patrick www.LightWingStudios.com Musical Instrument Protection Accessories...Made In America. Dell Precision T7910, Dual Processors (total 20 Cores), 128GB RAM, 4 @ 2TB SSDs, 1 @ 4TB HDs, Nvidia 2GB Dual Monitor Card, Dual LG 48" TVs used as Monitors, Arturia 88 Midi Controller, Black Lion USB Audio Interface, Mackie HR-828 Monitors, Katana Head, Fishman Triple Play, Win 10 Pro, PT 2023.3 Studio, only the Plugins I NEED, WAY TOO MANY Guitars...and an AMAZING wife! AxeShield HD, AmpShield HD, KeyShield HD, AxeSak, AxeGlove, AxeCap & PedalShield |
Serious question, are there any MIDI controllers that actually work with PT 11? | cdf2108 | Pro Tools HDX & HD Native Systems (Mac) | 8 | 08-28-2014 09:47 PM |
would m-audio AXIOM 61 midi knobs/controllers work in Pro tool LE? or only M-powered? | pein | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 07-29-2009 07:14 PM |
001 Midi inputs dont work in OSX 4 me. | WorkingEngineer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-22-2005 09:55 AM |
002R midi i/o ports dont work | ezko | MIDI | 0 | 02-02-2005 08:54 PM |
001 midi inputs/outputs dont work anymore? | El CaCa | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-10-2004 09:19 PM |
