Old 10-08-2018, 03:37 PM
dadiohead dadiohead is offline
Default Cannot Import Audio - help
Trying to import some discreet *.wav files recorded on a Mackie DL32 and
I get the following error message:
Could not complete the Import Audio command because Assertion in "/Volumes/Development/151228/ProTools/NewFileLibs/Cfd/MacBuild/../MacOS/Cfd_ImportAudioDialogMacOS.mm", line 575.
This has worked beautifully in the past but now it doesn't. Haven't changed anything in my set up for years other than upgrading to High Sierra. I have a late 2013 Mac Pro with 64 GBytes of RAM. I am running PT 11.3.1. I even tried re-installing PT and using drag and drop (which gives me this error message:
Assertion in "/Volumes/Development/151228/ProTools/NewFileLibs/AFnd/MacBuild/../Stems/AFnd_StemFormat.cpp", line 451.
Pretty disappointed that this is happening all of a sudden. Any suggestions on how I can mix my live recordings?
Old 10-11-2018, 05:32 AM
dougdi dougdi is offline
Default Re: Cannot Import Audio - help
11.3.1 will not work properly past Yosemite. I have the same Mac as you, I use an external Thunderbolt Lacie SSD drive to boot into Sierra. My internal drive is Yosemite so I can run 11.3.1. Otherwise I have the same issue you have using 11.3.1 with an unsupported OS. I am surprised how well the system runs booting externally with a drive that’s slower than the original SSD.
Old 10-11-2018, 05:44 PM
Import audio is a known bug when trying to run PT11.3.1 in Sierra or High Sierra.
I've been running an experiment here for the last three weeks. I split my SSD boot drive into two partitions. One for OSX 10.10.5 and OSX 10.12.6. Please note that I'm running PT 11.3.2 on both partitions. On the Sierra partition I can import audio but not by the menu item in PT; I have to use drag and drop from Finder. And that works just fine. The only other issues I've had were due to plugins needing updates but that was a doddle to fix.
MacPro cheesegrater with 3.46 GHz hex core cpu and 48 gig ram.
Jack
QAPLA!
Cannot import audio track via Import Audio menu item vibeone macOS 14 12-13-2018 09:10 AM
Import audio files on one track using Import Audio Command Sir Hannes Pro Tools 12 6 01-16-2018 01:50 PM
Import Video - Audio Import Option Disabled sarcanon Pro Tools 12 2 06-14-2016 05:12 PM
Import Session Data with out Audio import disinfor Pro Tools M-Powered (Mac) 7 11-14-2010 11:44 AM
Import Audio search window results will not import BA Studios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-25-2008 09:00 AM
