Waves 9, Licenses & iLoks
I've recently purchased a Waves 9 bundle to install on my company's Profile to fulfill a rider requirement for an upcoming gig.
Installed the complete Waves package fine, registered my serial with the Waves Site and then successfully transferred the License using Waves License Center to my USB stick to authorize the plugins on the console. The problem is, the license file is on my personal USB stick- I think I'd probably rather have the license stay on the iLok that lives inside the Profile. However, I wasn't able to 'see' the iLok as a vaild USB drive within Waves License Center. I don't have much experience with iLoks, so i don't know if that's normal (that they don't appear as normal usb storage devices). Is it possible to put the Waves License on an iLok? Or will I need to use a separate USB stick that gets carried around separately (or maybe installed in the Profile too). Lastly, I'm pretty sure I know the answer to this but is there any way at all to use Waves across multiple consoles that we own? If my company has purchased the license it would be nice to be able to use it on all our Venue systems.. doubt this but wanted to check. Pretty sure you can't just copy the authorization file across multiple sticks.. right? Apologies if this is more of a Waves question than Venue- but I am working solely in the Venue Live environment and uh, Waves support kinda sucks. |
Re: Waves 9, Licenses & iLoks
Did you contact them? |
I haven't talked to them about this specifically, my bad experience was with a previous issue. Thought asking here would be more direct as theoretically there's a bunch of people here doing the same exact thing I am.
Did you register iLok with the iLok company? My understanding is the software can only be put on one iLok which then is carried around or installed in the rack on which ever console you are working on, but I could be wrong as I am sorta of new to the iLok thing myself. I just found out that if you have Pro Tools 9 or 10 it has to be on an iLok which means I would need a second one because the first one has the plug-ins which is installed in the rack. I do not want to remove the ilok from the rack everytime I need to use Pro Tools.
Well Waves 9 does NOT use an iLok - it has its own authorization procedure as I described. I guess I want to know if i CAN put it on an iLok since that's what lives inside my Profile
I don't believe you can, BUT you can put a passive USB hub inside the local rack for your ilok and USB stick.
Regarding your other question, no you cannot use it on multiple consoles simultaneously, your authorization is for one instance only. |
Good thing with 9 is, if you put your license on the USB stick and loose it or put licenses on HDD and it fails, you can get new licenses from Waves. This is allowed to happen once a year, so this is borderline legal way to have your licenses on two places at the same time, in case you find the lost USB stick. And of course you wouldn't be able to ever update the licenses on the found USB. |
Thanks Brent and digidesigner for the info.
Purchased 9 new. USB hub is a good trick, met an engineer once who had built a really sick USB setup out of a tiny pelican case w a USB hub inside and a USB extender cable hanging out. All his installers, licenses and iLoks inside the case, no chance of snapping off or the like. |
-dj
iMAC 3.2GHz 6-core i7 250GB SSD (internal) 1TB SSD (external) 16GB RAM OSX 10.14.5 PT 2019.10 (last one) Waves Gold/RenMaxx v11 iZotope Ozone 8 Focusrite Clarett 8Pre Nord Stage 3 Nord Lead A1 DSI Mopho X4 |
No, you have got it wrong.
Cannot move licenses between Iloks with new ILM | panamajack | Pro Tools 11 | 9 | 08-11-2013 09:37 PM |
Waves v.9 TDM to get SoundGrid Licenses | joesackic | RTAS & TDM Plug-ins | 10 | 05-30-2013 03:47 PM |
FS: Waves Platinum Native Bundle V8 Ilok Licenses | Phil Pelissier | Buy & Sell | 0 | 08-22-2012 03:16 PM |
Waves TLC licenses download question | WildHoney | Pro Tools TDM Systems (Mac) | 0 | 01-02-2011 03:02 PM |
Transfer waves between user iloks | crizdee | Pro Tools TDM Systems (Mac) | 6 | 02-13-2006 12:51 PM |
