Transfuser and Axiom Pro?
I am getting in to Transfuser and I have an Axiom Pro but it does not auto map to Transfuser like it does to all the other plugins in Pro Tools. When I open Transfuser and load a sample and then press play on the Axiom Pro it starts the PT transport but not Transfuser. Also none of the other controls work? I am stumped?
Any help will be greatly appreciated. |
Re: Transfuser and Axiom Pro?
Transfuser requires MIDI event data on the Pro Tools timeline to initiate playback. Also Axiom Pro with Transfuser only maps automatically to the Controller Section Smart Knobs.
Aaron Mulqueen - 001 HD Native |
Now what about the drum pads on the axiom? Plus Phil Jackson presses the play/stop in his video and it works why then does it not work when using the axiom pro? |
Can you please hyperlink that video and at what time the operation you are referring too?
Do you have the axiom pro set up in the peripherals/midi controllers box
Here is the one he uses the axiom to start and stop and trigger the drum pads in transfuser. Here is one where he say the play and stop are auto set to the axiom play and stop. There are a bunch more video there to watch and the show how Transfuser can be operated from the Axiom. I have found that the Axiom Pro is auto set to use the 8 knobs to operated the 6 smart knobs, master volume and pitch. But what about the X Fader and drum pads? Avid should make a patch that you can call up just to operate Transfuser form the Axiom Pro. |
Yes it is set Hypercontrol send and receive. My Axiom Pro works perfect with everything else but I can not get it to do what Phil Jackson is doing with the Axiom.
X-Fader is part of the Group E assignments and the Trigger Pads need assigning to Group P. This is covered in the Axiom Pro User Guide.
I'm super late to the party as usual, but as far as the pads go was this what you were looking for?
http://tinyurl.com/3ckes8l
--------------------- Darth Hobo, Dark Lord of the Synth ========= Last edited by Linhardt; 04-28-2011 at 11:26 AM. Reason: shorten link |
I think it will be much easier to just get a trigger finger or maybe a MPD to have just to control the Transfuser. The Axiom Pro is very good at all the other stuff and its locked in Hyper Control with Pro Tools. |
help with axiom 49 in transfuser | thisistruth | MIDI | 1 | 12-30-2011 02:13 AM |
Losing Axiom 61 Control in Transfuser | senordumb1 | Virtual Instruments | 0 | 01-05-2011 03:58 PM |
Transfuser pads mapped to axiom pro pads | th3actor | Virtual Instruments | 0 | 09-02-2010 04:22 PM |
Axiom Pro & Transfuser Master Transport | filosofem | Virtual Instruments | 11 | 10-21-2009 06:33 PM |
Transfuser/Axiom Transport issue | psi777 | Virtual Instruments | 0 | 02-04-2009 10:28 AM |
